oil pressure sender
Old Dec 22, 2001 | 02:22 AM
tiburon_fx_pa's Avatar
Default oil pressure sender
does anyone know where the oil pressure sender is on a tib????????????
Old Dec 22, 2001 | 03:32 AM
Jaws99's Avatar
Yeah it is to the right of the exhaust manifold it is gold in color, has one wire running from it and is ocward shaped you will also see another sending unit to it's right that has to be unscrewed to remove and is covered by a black rubber boot but the one that has to unscrewed is not the one you want I just told you about that one to give you a better idea to where it is.
Old Dec 22, 2001 | 02:29 PM
thanks will try to accomplish the task tomorrow...
Old Dec 26, 2001 | 07:36 AM
what'cha doing?
Old Dec 31, 2001 | 08:35 AM
installing an electronic oil pressure gauge...got done two days ago works good....thanks
