Off-idle Stumble
Old Nov 13, 2008 | 10:29 AM
97DerekTiburon's Avatar
I have a '97 1.8 with new: fuel pump, fuel filter, injectors, CPS, plugs and wires. It had a terrible problem running last year and took it off the road. I've slowly fixed/replaced things (injectors were FULL of mud so I redid most of the fuel system!)
Now it starts up and idles nice and I can rev it up nice but the first moment I rev it, it stumbles and clears itself up. I can rev it up after it stubles, let it settle down and rev it up with another stumble.
If I let it idle a minute, it'll stumble again just off-idle. If I was in gear and tried to drive off, it'd almost stall unless I reved it up and rode the clutch a bit.
BTW, No CELs even with the fuel injectors clogged with crap and it running terribly.
Old Nov 13, 2008 | 11:34 AM
bassboy3313's Avatar
Vehicle: 1997 Hyundai Tiburon FX
i got the same problem right now. i bought a new tps and once it gets here ill see if that fixes it.
Old Nov 13, 2008 | 12:45 PM
Cool. I'm gonna check my plug gap as well.
I'm going to pick up a can of Seafoam tonight and get some good, new gas in the tank.
Old Nov 13, 2008 | 02:37 PM
zoned019's Avatar
Vehicle: 97 Tib
Are you sure that your MAF is oriented in the right direction?
Old Nov 13, 2008 | 06:29 PM
It's never been off since I owned it. How can I know for sure?
Old Nov 13, 2008 | 08:21 PM
There's an arrow on the MAF indicating proper direction.
I'd definatly check your plug gap. I'd also check for vacuum leaks. Do you have a CEL?
Old Nov 13, 2008 | 09:00 PM
stealth's Avatar
Vehicle: 2000/Hyundai/Tiburon
QUOTE (DTN @ Nov 13 2008, 10:21 PM)
QUOTE (97DerekTiburon @ Nov 13 2008, 12:29 PM)
no CELS
Old Nov 13, 2008 | 09:36 PM
wut if my maf sensor is not in the housnig anymore. I have it bolted in my charge pipe for my IC piping. how will ik if its backwards or not without the housing for it?
Old Nov 14, 2008 | 06:25 AM
Sounds like the usual culprit, the TPS. Test it.
Old Nov 14, 2008 | 07:38 AM
how do u test the TPS?
