O2 spoof.
I have a US 2002 Elantra GLS. I am looking for an O2 spoof "for offroad use only". Anyone know where I can find one or if one designed for a different car will work? Thanks for any replies.
I found this doing a search but it does not look like it will work as there are too many wires. The O2 sensor on my car has 1 wire. Still, any help would be appreciated.
http://casperselectronics.com/cgi-local/st...product=IMPORTS |
Actually there is not enough wires. If your sensor is the same as the Tibs, then you should have 4 wires. They are heated sensors with:
1. o2 signal 2. ground 3. heater 4. fuel relay You may not need the fourth for the fuel relay |
<div class='quotetop'>QUOTE </div><div class='quotemain'>JonGTR:
You may not need the fourth for the fuel relay</div>What does the "Fuel Relay" wire do? |
In fact both hyundai (front and rear) O2 sensor uses 4 wires...
02 signal 02 ground 12 volts for heather (what some call fuel relay) heather ground Denis |
I have an O2 simulator made by Casper Electronics which is avail from Summit Racing, but have yet to get it to work on my 2001 elantra. I keep getting heater malfuctions with it. And yes the 2001+ elantra's have 4 wires on 3 that are in use for the #2 O2 sensor which is where you need to hook it up. The one that is not in use is the fuel relay which is used in the #1 O2 sensor only for fuel trim. Why they hooked up 4 wires on the #2 O2 sensor I have no clue. Also what wire colors are what on this thing. Maybe I had it AFU when i wired it the first 5 or 6 times lol.
| All times are GMT -6. The time now is 05:57 AM. |
