O2 sensors
Old May 26, 2001 | 08:15 AM
C-nut's Avatar
Default O2 sensors
Im confused i recently got the
4-2-1 headers from SR, and it said that it only came with one O2 sensor connection. My car has two, and I know i need to drill another hole to connect the other O2 sensor. The problem is, I don't konw where. there is no more collection point for the first O2 sensor to get a mass reading. I don't want to plug it into one pipe because there may be different amounts of air/fuel mixture coming out from each port of the head. where should the O2 sensor be put in order to get an accurate reading? any suggestions?
Old May 27, 2001 | 10:30 PM
Brendan's Avatar
The first o2 sensor has to go where all the 4 runners meet, the 2nd goes behind the cat ( you better be putting a new cat in ) the first o2 will rach the hole cut in the headders if you lossen the wire harness it attatches to, the 2nd o2 you may need to extend it.
