No Speed Gauge And Odometer.
Old Jul 21, 2007 | 05:22 PM
Whiplash's Avatar
Vehicle: SRT4/Neon SOHC
Whats the part called that needs to be replaced once the speed tach and odometer stop working on a 99 tib?
Old Jul 21, 2007 | 06:13 PM
That's a pretty vauge question man.
Tachometer, speedometer, instrument cluster, speed sensor, ECU.... am i getting close?
Old Jul 21, 2007 | 06:35 PM
Whiplash's Avatar
Anyways, the speedometer and the odometer stopped working. Same thing happened when I had my tib. I just forget what the part is called.
Old Jul 21, 2007 | 08:52 PM
Probably the little gear that goes into the tranny to send the signal to the speedo.
Old Jul 21, 2007 | 10:03 PM
Denisst99's Avatar
did you check the fuses?
Old Jul 22, 2007 | 09:18 AM
Whiplash's Avatar
My dad was playing around with the fuses because the wipers stopped working. Then when I turned the car on and drove off I noticed the speedometer and odometer werent working...
Do you know which fuses might be to blame?
Old Jul 22, 2007 | 09:26 AM
I've had my cluster loose before and the gauges stopped working.
Check fuse 10. The speed sensor is not the problem. It must be fuse 10.
Old Jul 23, 2007 | 01:45 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I bet it's something with fuse or wires.
Old Jul 23, 2007 | 02:28 PM
I just re-read the symptoms. Is the speedometer the only one that does not work, or is it the speedometer and tachometer?
Old Jul 23, 2007 | 02:42 PM
Tibbychick's Avatar
My odometer hasnt worked for the past 2 years. I dont know how much mileage my car really has 02.gif I think I checked the fuses though, since thats what I was gonna suggest for you to do. Other than that I dont know.
