| tibbypimpin |
Sep 28, 2007 01:48 PM |
Ok i just put a moter and traney in my 1998 tiburon.about a month after the install ,i started noticing that to put in to first gear it took some force to shove it in...now it will sometimes go into 1st if i shove over and up real heard and fast,and now second is startin to do the same,sometimes,I have a shark racing short shifter,and i can reach in the engine and go through all gears by hand,but for some reason i cant get it to go into 1st using the shifter.Does anyone have any ideas,is it the cabol for the gear select,does it need adj,any help would be greatfull
