Re: cuda kit
hey.. i was working on my suspension and i accidentally pulled out the drive shaft out of its sleeve and then some sort of fluid came pouring out (im assuming its gear oil) ..
i put the drive shaft back in and it stopped the leak. now my question is, what do i do now? do i have to refill the fluid? how do i do that if so? and what do i fill it with? and i cant get to a shop right now so can i still drive my car? is it safe? any info on this will help.. thank you guys! |
Re: Kspec Maintec Header/Turbo Manifold GB *8 of 12*
How much fluid did you drop? Also, do you have an automatic or manual transmission? I don't know shit AT. For MT, you'll need GL-4 gear oil - Redline MT-90 recommended. I know for MT, there's a big nut on the side of the transmission (17mm or so I think), unscrew that, and pump your fluid in.
Re: Haloz install help
<div class='quotetop'>QUOTE (a_gut)</div><div class='quotemain'>How much fluid did you drop? Also, do you have an automatic or manual transmission? I believe for AT, get a ride to the local auto parts store and get some generic AT fluid. For MT, you'll need GL-4 gear oil - Redline MT-90 recommended. I know for MT, there's a big nut on the side of the transmission (17mm or so I think), unscrew that, and pump your fluid in.</div>
DO NOT USE "GENERIC AT FLUID" Use the Hyundai stuff or Diamond ATF+3 ONLY!!! Trust me. |
Re: Car has no sparkie
hi.. sorry for leaving this out. i have a manual trans.
i leaked out about half a can of coke worth of gear oil approx.. so this bolt you are talking about, is it under the car? do i have to hoist the car? and how do i put this stuff in if its under the car? do i have to drain out what i have now if i want to put a different kind such as redline mt-90? and also how do i know how much to put? kayjai, what do you mean by "GENERIC AT FLUID" ? thanks for the help guys! |
Re: two pix of my tib
Yes the bolt is under the car, you'll have to jack it up some, no more than if you were changing your motor oil.
http://www.hmaservice.com/webtech/ Go to that website, enter your car in, and lookup how to change your gear oil. It'll show you pictures and directions on what to do. I suppose you could just top it off, if money is tight, but you may as well change it all to be safe. The hmaservice website says 2.25 US quarts. The bolt for putting fluid in is mounted sideways, so it's a bastard to put in without a pump. You can buy one at your local autoparts store for like $2, or you may find a usable one around the house. |
Man, MT 90 is so hard to find, i had to go to 6 different shops in my town. And he only had one bottle. Had to get it specially orderd.
I am going to mix it with some lucus when i change it. I would recommend that if ur going to change it all over...[/list] |
Re: WTB: Tigerlilly Pistons
if you use lucas do you put in the normal amount of redline then the lucas??
I've got a brand new tranny though, would lucas even be a good idea? |
Re: cuda kit
thanks guys...
do you mind if i ask what lucus is ? |
Re: Need Help ASAP!!
AT = Automatic Transmission
Lucas = Oil Additive, a particularly good brand. |
is lucas recommended ? for gear oil or engine oil?
