Hyundai Aftermarket
-   -   my x3 problem (https://www.hyundaiaftermarket.org/forum/engine-intake-exhaust-11/my-x3-problem-74092/)
98x3beta Jun 16, 2013 05:19 PM
my x3 problem
Small but big problem i have right now. I just moved to the north west area and I just bought an x3, but the car hasn't been touched since November of last mount. Ok right now my tail light (driver side) doesn't work when I turn on my lights, only the right one. But when I step on the breaks it comes on. I already tryed a new light bulb I'm confused right now... if anyone can help I appreciate it
Another thing is my driver side signal light doesn't work when lights are on but ( blinks) when I put the signal on!
I'm confuse so anything helps
Last year**
2FastElantra Jun 16, 2013 09:52 PM
Check fuses?
98x3beta Jun 17, 2013 12:01 AM
But wouldn't a fuse blow out the whole entire light aassembly??
wheel_of_steel Jun 17, 2013 10:02 AM
Check the security of the wiring to the taillight itself, especially the park circuit and all your grounds
Then check if the turn signal is getting power and earth and diagnose back towards the cabin/battery from there
98x3beta Jun 17, 2013 01:26 PM
Will do thanks.
98x3beta Jun 21, 2013 12:57 AM
Fixed it...
First I went to the junk yard to go get a new harness just to see if it would work... didn't not do the trick. So I found where my (passenger side) tail was getting itspower so I traced my way further in the car and found the wire that I spliced and connected to my tail light and that fixed everything my signal light and my gauge cluser with its lights out!
