my x3 problem
Old Jun 16, 2013 | 05:19 PM
98x3beta's Avatar
Vehicle: 1998/Hyundai/accent
Default my x3 problem
Small but big problem i have right now. I just moved to the north west area and I just bought an x3, but the car hasn't been touched since November of last mount. Ok right now my tail light (driver side) doesn't work when I turn on my lights, only the right one. But when I step on the breaks it comes on. I already tryed a new light bulb I'm confused right now... if anyone can help I appreciate it
Another thing is my driver side signal light doesn't work when lights are on but ( blinks) when I put the signal on!
I'm confuse so anything helps
Last year**
Old Jun 16, 2013 | 09:52 PM
2FastElantra's Avatar
Vehicle: 2005 Hyundai Tiburon GT
Check fuses?
Old Jun 17, 2013 | 12:01 AM
98x3beta's Avatar
But wouldn't a fuse blow out the whole entire light aassembly??
Old Jun 17, 2013 | 10:02 AM
wheel_of_steel's Avatar
Check the security of the wiring to the taillight itself, especially the park circuit and all your grounds
Then check if the turn signal is getting power and earth and diagnose back towards the cabin/battery from there
Old Jun 17, 2013 | 01:26 PM
98x3beta's Avatar
Will do thanks.
Old Jun 21, 2013 | 12:57 AM
98x3beta's Avatar
Fixed it...
First I went to the junk yard to go get a new harness just to see if it would work... didn't not do the trick. So I found where my (passenger side) tail was getting itspower so I traced my way further in the car and found the wire that I spliced and connected to my tail light and that fixed everything my signal light and my gauge cluser with its lights out!
