My Engine Before Accident In My Silver Tib
AIRRAM Inatke manifold
Old pics..
Complete 2.5" Exhaust
and the last Upgreat I buy is this kit I can't ever installed because that week im go to
due and I have the accident
I always want something like this:
Old pics..
not bad.. having a turbo tib is always good..
but having accidents = no good.
when i had my tib, it was in a few accidents, but always fixable.
looked like a pretty decent setup. what were you using for fuel management.
AIRRAM Intake Manifold------------------------$1,300.00
RSide Throttle Body----------------------------$375.00
RC 750cc Injectors-----------------------------$450.00
Clutchmasters Flywheel-------------------------$500.00
Clutchmasters Stage 4 clucth kit----------------$600.00
Walbroo 255psi fuel pump-----------------------$120.00
Apexi SAFC-II black-----------------------------$345.00
Apexi Turbo Timer Black-------------------------$180.00
AEM Wideband, Oil and Boost-------------------$920.00
OBX Turbo Manifold-----------------------------$222.00
Turbina T3/T4----------------------------------$385.00
Turbo oil feed and drain lines--------------------$95.00
Intercooler 2.5"---------------------------------$265.00
Intercooler Piping kit----------------------------$165.00
Silicone 3 layer Coupler+Heavy duty T Clamps----$240.00
Tial 50mm blow off------------------------------$260.00
Tial 38mm wastegate---------------------------$240.00
Fly Ryde Traction Bar---------------------------$365.00
Unorthodox damper pulley-----------------------$280.00
YAYA suspension bushings----------------------$250.00
Eibach Sway bars------------------------------$390.00
KYB AGX shocks-------------------------------$560.00
Cross drilled rotors----------------------------$450.00
Braided Stainless steel brake lines-----------$195.00
H&R springs son los mismos del cup kit q salio en $875.00 le resto esto
KJB Motorsports Adjustable Sway Bar Endlinks---$175.00
KJB Motorsports Delrin Shifter Bushings---------$25.00
KJB Motorsports Shifter Base Bushings----------$25.00
B&M short trow shifter-------------------------$121.00
KSPEC Engine Mount Set for Turbulence--------$200.00
Turbulence Front Strut Bar---------------------$100.00
Turbulence Rear Strut Bar----------------------$100.00
Centerbar for Turbulence-----------------------$110.00
Turbulence cluster gauges Marine Blue-------$44.00
Turbulence Intake Cam Sprocket-------------$140.00
Fidanza Exhaust cam sprocket----------------$100.00
OBX Pulley Kit 2 pieces------------------------$90.00
Nology Hot Wires------------------------------$165.00
NGK 2668 Iridium IX---------------------------$70.00
KDM 3mm Turbo Head gasket----------------$300.00
ARP Head studs--------------------------------$140.00
OBX radiator hoses----------------------------$50.00
Oil catch can-----------------------------------$45.00
HID H7 10000K--------------------------------$300.00
HID H3 10000K--------------------------------$290.00
ATH front lip spoiler---------------------------$225.00
Pivot Raizin Volt stabilizer+ ground wires---$125.00
ZEX Nitros WET system-----------------------$880.00
and much more:
and much more:
holy crap you wasted a ton of money on that air ram.. i paid 550$ for mine....
and 920$ for 2 gauges? i think i paid like 650$ for wideband, EGT, boost, oil temp, oil pressure gauges.
385$ for a turbo, im assuming used, or off ebay?
and 1100$ for a clutch kit and flywheel combo..
"I see a cool air intake. Its got a Nos fogger system and a T4 turbo, Dominic. I see an AIC controller. It has direct-port nitrous injection. "
"Yeah, and a stand alone fuel management system. Not a bad way to spend 10,000 dollars."
ROFLMAO....
ROFLMAO....
