looking for new intake
so i just got my tax return so im looking to get some new parts and one thing i literaly just thought of is a new intake. currently i have a custom built one but im looking for some thing better such as aem or k&n, now i know K7n dosnt have on i checked and im looking know but i figuered id post and get ppls opinons
You basically have 2 options for cold air intakes...
- AEM style where the filter sits in your fenderwell - Injen style where the filter sits below your battery box There are alot of knock offs on Ebay that are cheap, but they may not have the same diameter piping as a true AEM or Injen. They have 3" piping, where as the knock off's usually have 2.5" and they include cheap filters. The knock off's also usually are one piece which means you'll have to cut them up if you want to add any kind of a by-pass valve (some people use them as piece of mind in case they get ALOT of rain or wet weather where they live). The power difference between a true Injen or AEM versus an ebay knock off is minimal though. You're probably only looking at a 2-3 horsepower difference, if that. If you want to save money, go the ebay route (but get a good filter like k&n). If you want to support industry leading products with a good R&D behind their products...go name brand. |
i have a injen for a rd/j2 platform for cheap
im not sure if it will work |
Thats a short ram...not a cold air.
While a short ram will give you immediate throttle response, it wont give you anywhere near the same performance as a cold air intake will. Reason being is that it sucks in hot air from your engine. In order to gain the most power possible from an intake, you want colder and more dense air. A cold air intake will draw in cooler temps because the filter is placed either down below the engine (under the battery like an Injen style) or outside the fenderwell (AEM style). |
true so i think i will go with a injen cause i havent found an aem one that looks like it will fit unless anyone has one that knows fits nicely please let me know
again ill sell you my injen for cheap
like $50 cheap comes with a k&n filter |
^ GREAT deal...I would hop on that ASAP.
ight ill get yours off you but i wont have the money till friday
Your other optionis a 97-99 4cyl. Accord intake (2 piece). They can be had cheap on ebay and they fit the XD Elantra perfectly. Then you just add the filter of your choice.
<div class='quotetop'>QUOTE (faithofadragon @ Feb 9 2010, 02:14 PM) <{POST_SNAPBACK}></div><div class='quotemain'>again ill sell you my injen for cheap like $50 cheap comes with a k&n filter</div> Is the intake from a J2 Elantra going to work on an XD? |
