Looking For High Comp Pistons.
Old Aug 23, 2006 | 03:02 PM
wagonofhell's Avatar
I am looiking for some high compretion pistons for the betaI, any ideas?
Old Aug 23, 2006 | 04:19 PM
xxxmonoxidechild's Avatar
well if you have the 2.0, a stock set of 1.8's work.
Old Aug 23, 2006 | 04:32 PM
importshark's Avatar
I am almost ready to add Wiseco Pistons to the website, for 2.0L Beta1
Comp ratio is 8.7-9.0
Is that high enough or you looking for higher
Old Aug 23, 2006 | 04:34 PM
^^lol thats lower than stock mang
those are turbo pistons
Old Aug 23, 2006 | 04:52 PM
DUUOOOT ...... brainfart ........ ye, I guess your right apperently I'm not all together today.
Old Aug 23, 2006 | 05:28 PM
Tiburonsrule's Avatar
Vehicle: 2000
i know that hyundaiperformace.com has a set but i dont know the quality. you can get wiseco to custom make a set
Old Aug 24, 2006 | 01:10 AM
It is the beta1 2l. Can I just put the 1.8 pistons in and get 11-1? I really want 12-1, if the bore is 82mm then any 82mm piston will work right?
Old Aug 24, 2006 | 03:22 AM
i believe the 1.8L pistons wil get you 11.3:1 compression ratio.. and they would pretty much drop right in.. if i ever get another tib, i will be running N/A with those pistons, and a bunch of other goodies..
Old Aug 24, 2006 | 06:55 AM
milling the head can get you some higher compression but can also mess up the quelch area if not done right
a machine shop can tell you whats recommended
Old Aug 24, 2006 | 09:21 AM
Zman's Avatar
QUOTE (wagonofhell @ Aug 24 2006, 02:10 AM)
Yeah, and you also have to change the OEM head gasket for the Beta2 head gasket.
If you are aiming to higher than 11,3:1 you have to get some kind of ECU tuning; I don't think your ECU will manage that compression (it should change your emissions a bit) by its own.
And I don't think any 82mm piston will do mate... for starters the 2.0 is a 82mm piston and compression is lower isn't it? It depedns on the top of the piston design; BUT you also have to figure out piston pin configuration, skirt size, very important: weight, etc, etc; so NO; NOT ANY 82mm PISTON WILL DO.
