Last Queston About My System Upgrade Bbtb From Seoulfulracing.
Old Mar 18, 2007 | 07:25 PM
daniel_depetro's Avatar
OK, I never had this many questions about an item as simple as a BBTB, but the last couple BBTB's I have had for other cars have been bored out originals.
Anyways my System Upgrade 60mm BBTB I got from SeoulfulRacing has a port hole that is drilled in the top of the throttle body just before the butterfly. The port hole id open and comes out the top of the back side by the intake manifold. It is open. I assumed that it would be covered by the gasket but it isn't. It isn't covered up by the phenolic spacer either. I was surprised that my car idles at ~750-850 RPMs and runs great.
Any ideas on this?
I can't imagine it is suppose to be open. I mean that is some hot & unfiltered dirty air that would be sucked in through there.
If you look at this pic you can clearly see the port hole I am referring to. It travels up into that block and takes a 90 out the backside. why would this be left open uncovered?
Old Mar 18, 2007 | 07:32 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
that hole is so you can set up the IAC for the beta2 but they didnt finish the stuff to make it functional for those engines. still making it work on the beta1
Old Mar 18, 2007 | 08:09 PM
Thanks, what should I do?
Should I plug it somehow?
I thought about silicone, but I'd hate that idea if it got sucked into my engine.
How does that not create a vacuum leak or anything?
Old Mar 18, 2007 | 09:19 PM
Teflon's Avatar
JB weld will do.
Thats what i did with mine.
Old Mar 18, 2007 | 10:23 PM
col96fx's Avatar
Vehicle: Hyosung GT650
It won't create a vac leak b/c it's b4 the butterfly, but it will suck in unfiltered air so plug it with something.
Old Mar 19, 2007 | 03:43 PM
Thanks guys!
