Kore filters
Old Jan 13, 2003 | 05:38 AM
Viper966's Avatar
Default Kore filters
My car would not idle today after a quick WOT burst 0-30...
so i started checking the usual fuel/air/spark deal and found this
this is the piece that fell off next 2 the filter
this is where it was supposed 2 go (i had 2 clean the outside cuz it got my counter dirty.. im not reusing htis filterobviously)
and this is where it was supposed 2 go
i dont know exactly where the metal piece ended up cuz when my car died i disconnected the piping right after teh bypas valve and than i started up 2 car (to check if my filter was jus clogged or the bypass valve had malfunctioned) and i heard it hit the ground after about a minute of idling... but the filter was still on tite so it had to have been in the upper intake pipe
Old Jan 13, 2003 | 05:44 AM
it was probably resting up against your MAF grill.
I've seen similar problems with some aftermarket filters, but this is my first experience of this happening with a KORE filter.
Old Jan 13, 2003 | 05:51 AM
Viper966's Avatar
tony can u imagine what woulda happened if i was running a turbo... geez
Old Jan 13, 2003 | 07:53 AM
Denisst99's Avatar
I advised the members of our club against the use of this type of air filter last year...i must see at least 6 of them each year with a popped center cap...
The problem isn't the glue wich is holding the center cap,it's the paint,paint "unstick" from the cap and the cap falls in your intake piping
Newer ractive (and all other using the same style) are now using a chromed center cap wich seam to solve the problem
Now think about one minute...
if he had a MAP equiped car where would the cap end up?I'm sure it would have stuck itself in the TB while he was at WOT....
Denis
[ January 13, 2003, 02:54 PM: Message edited by: Denisst99 ]
Old Jan 14, 2003 | 12:35 PM
Snowman's Avatar
KORE has also switched to filter that does not have this problem..
Old Jan 14, 2003 | 12:56 PM
KayJai's Avatar
Viper, do you have a pic of the other side of the filter?
If you do, can you post it,...
Thanks.
Just curious about something.
J@WS01 had this happened too.
However, he was jumping off the rev limiter alot at the time, so I guess it just backed up and pushed his off.
Old Jan 14, 2003 | 03:07 PM
Viper966's Avatar
yea ill post some more 2morrow...
Old Jan 15, 2003 | 01:04 PM
KayJai's Avatar
[anxiously waiting]kewl,...[/anxiously waiting]
wink
Old Jan 21, 2003 | 11:45 PM
KayJai's Avatar
Viper,... got those pix yet?
