How Much HP
Old Oct 28, 2002 | 01:11 PM
mohead's Avatar
Vehicle: 2K Accent
power steering belt. Put the belt back on when you leave the track. It's the little things that make power and lower times.
[ October 28, 2002, 08:14 PM: Message edited by: mohead ]
Old Oct 28, 2002 | 01:36 PM
JAWS 021's Avatar
over inflate tires?
you sure?
Old Oct 28, 2002 | 01:50 PM
mohead's Avatar
Vehicle: 2K Accent
Yes I sure. You over inflate tires for less rolling resistance. Less resistance means lower times. Don't forget to reset your tire psi before you leave the track.
Old Oct 28, 2002 | 03:44 PM
Josh's Avatar
Vehicle: 1997 Hyundai Tiburon FX - now 2006 Infiniti M35 Sport
I ran a 17.8 in my auto with intake/headers/RT-cat/exhaust without the nitrous.
You should get in the 17's as well.
Higher end should feel better after you put those in.
...and yes, overinflate.
Old Oct 28, 2002 | 10:14 PM
plantenutz's Avatar
Josh:
Wow thats pretty crappy times you ran with I/H/E,was the air bad or something?I have I/H/E/C and high flow cat,and my g-tech times are consistently around 16.0-16.1,i have tested it many times and i'm hoping after the BBTB i'll be in the 15's.
Old Oct 28, 2002 | 10:39 PM
KillerShark68's Avatar
Vehicle: 2007 Tiburon
How about using the money to swap the auto out for a 5-spd. Then get the rest.
All the mods you wanna buy with an auto is not worth the money.
Old Oct 29, 2002 | 01:34 AM
Brendan's Avatar
Don't bash the tranny, and as far as a waste!! I'm auto and run 15.7 ish now, so what do you say now, post up a time slip.
Old Oct 29, 2002 | 08:39 AM
mohead's Avatar
Vehicle: 2K Accent
How can your car run 15.7 in the 1/4 mile when your country is metric? hahaha
Old Oct 29, 2002 | 09:58 AM
Josh's Avatar
yeah, really bad time...It was a very bad day to go to the track... Rained that afternoon and tires didn't grip well. Humidity was terrible and it was in hot Georgia heat. My friend in his 2k integra (base model) did exactly the same time with the same modifications as my car.
I didn't mention that I ran a 15.9 the same night with the nitrous. But that was spraying off the line, losing traction all through first, and hitting the rev limiter... sad.gif
but 5k miles later, the motor's still fine.
(He said 15.7-ISH)
Old Oct 29, 2002 | 11:46 AM
TiburonGuy99's Avatar
Vehicle: 99 Tib
also after i get the intake and cat-back i was thinking i should go ahead and get the 1.8 gt cam that should help me get the most out of these mods.
