Hose connected to BBTB
Hey Random,
I appreciate your expertise on my problem earlier but I need it again. The hose connected to my new BBTB(Purple by the way)does not appear to be large enough to put the BBTB into it. I have looked everywhere to find somekind of adaptor(Napa, Roy Rogers, etc.) but no luck. I need to know what to do as soon as possible. I am needing to get my car back together tonite!!!!!HELP!!!! Thanks in advance.
My son calls my car a "RaceCar"!!!!
It will fit. It is a tight strech, but it does fit.
Make sure you really losen up the hose clamp so it does not interfere with the streching.
I've done 2 or 3 of them, and they are a strech, but it is possible. If you "lube" the inside of the that rubber elbow just a bit, it is easier.
Hey Random,
Thank you for the awesome advise. I was afraid that I was going to have to go on some "wild hair chase" to locate a fitting so that this all would work. Thanks again. Your advise is priceless.
TSR Member#95
1999 Red Tibby
Auto
Bosch Platinum 4Plus sparkplugs
Magnecor 8.5mm wires
K&N dropin filter
PaceSetter Cat-Bak System
PlasmaGreen Backup Lights
My son calls my car a "RaceCar" !!!!
TSR Member#95
1999 Red Tibby
Auto
K&N dropin filter
