Help Me Now Please!
Old Mar 10, 2007 | 11:01 AM
BlizagaXx's Avatar
Vehicle: car
A f***ing cam journal bolt broke off on my engine, is there any way to get it out? its the cam journal bolt. theres a little metal sleeve that raises above the block. help?
Old Mar 10, 2007 | 11:33 AM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
are you able to use a pair of vise-grips to spin it out? possibly an easy out tool, or left handed drill bit (spins opposite of other drill bits to help remiove bolts) ?
Old Mar 10, 2007 | 01:06 PM
BlizagaXx's Avatar
Vehicle: car
I got it out, cams installed, all is well.
Old Mar 10, 2007 | 05:11 PM
StrikeEagle's Avatar
Did you just use a vice grip?
Old Mar 10, 2007 | 09:35 PM
BlizagaXx's Avatar
Vehicle: car
Put it this way, I was torquing the cam journal bolt down. I was using a monster torque wrench. I rented it from work, the neglected to tell me it started at 40 foot pounds, so I ended up putting 49ft/lb of torque on one. I ended up shearing a bolt off in the block. mad.gif . so It looked like this
_ _
|_|
It got all messed up... I ended up taking a pick type thing, and a hammer to it. I started hitting the pick on the side, so it turned like 1/16 of a turn each time. I got it out slowly though. What even better is I call Hyundai to see if they had a cam journal bolt, the guy from parts says "A cam what?". I just said "I'm coming up there" after he told me they don't carry them. I go up there, hand him the bolt, he walks in the back and gives me an identical one, but he gave me it for free, so that's cool. Good news though! Only 290 more miles to break it in!! I've already driven 10!!! owned.gif
Old Mar 10, 2007 | 10:47 PM
Hyundai92Excel's Avatar
Vehicle: 1992 Honda Accord EX
Nice recovery.
Old Mar 11, 2007 | 12:21 AM
Old Mar 11, 2007 | 12:27 AM
BlizagaXx's Avatar
Vehicle: car
I know I'm supposed to do the break in period, but does the 1.8l cam really make that much of a difference? What are the main gains? My intake doesn't seem to have as much suction as of right now, and my car seems sluggish. Does this happen until the ECU gets used to it? I bought the cam BRAND NEW from REDZ... I installed it, just one little problem, but I fixed that. Everything is lined up right, I'm doing an oil change tomorrow hopefully. But are these gains noticeable? Is it more on higher or lower RPM's, anyone know the horse gains? I'm so confused!! I just installed this cam, and I have no clue how it helps me (what does this smaller cam do?), or how much it helps me!
Old Mar 11, 2007 | 04:17 AM
Tiburonsrule's Avatar
Vehicle: 2000
For one it isnt a smaller cam.it is actually slightly bigger. not much maybe 5 degrees or so i dont remember. Gains will be felt near to the top end i believe.
Old Mar 11, 2007 | 09:37 AM
Did you not reset the ECU? RESET THE ECU!
