Full Rebuild While I'm In There?
I'm going to have a rebuilt head
I'm going to have the transmission off for replacement
I'm going to have the pistons/rods out to install the 1.8L pistons...
Why not throw some new stock-sized bearing shells on the big-ends and mains, and throw front & rear bearings & seals in there while it's apart? If I get a full rebuild kit, they'll likely be in there anyhow...
Is it worth the effort to replace the rod & main bearings & main seals with stock size, without checking clearances, when nothing is falling apart or leaking (yet)? I'm also inclined to let it go until it does start leaking. I should get an oil pressure gauge too eh.
unless you know a good shop that could fabricate all that for cheap, and you're diggin in there anyways go for it. i would do it, but it might end up costing a bit more than just replacing the engine.
fabricate what?
shop? You mean, my garage!
It's all in a full-tilt-boogie engine rebuild kit, including the parts I'd need for the head, so a couple hundred bux tops.
The engine runs fine now, but I *am* going to be in there so I thought I'd get a few more opinions.
