Fuel enrichement
Old Aug 11, 2002 | 09:15 AM
Lobert's Avatar
Default Fuel enrichement
Hello all...... Here's what I have in mind to do the fuel enrichment on my 2k1 GL w/turbo. Build a Window Comparator connected to the O2 sensor. That way anytime that O2 sensor voltage would drop below a pre determined point, it would turn on a "Cold Start Injector" from a Vw Golf, and spray additional fuel into the intake.
Now......My question to all is....Am I just chasing my own tail on this or do ya'll think it would work???????? BTW, my car is currently off of boost, due to the fuel problem. (Thought I had it figured out but, I hooked it up to a OBD-II scanner and found out that I was running Waaaaaaaaaaaaaayyyyyyyyyyyyyy Lean.
Old Aug 11, 2002 | 03:04 PM
Shadohh's Avatar
Hyundai engines do not have a cold start injector, they use Cylinder number 1 injector. which is the same one used during normal operation.
Old Aug 12, 2002 | 04:53 AM
Lobert's Avatar
I never said that my engine had a cold start injector. I said that the injector is from a VW. That's the one that I am gonna mount in the intake.
Red, anybody else got any ideas about this?????????
Old Aug 12, 2002 | 05:30 AM
Red's Avatar
Red
Hmm...
I don't suggest running it from the O2 sensor, you're just asking to kill an engine when the O2 sensor dies. And yes, I said when the O2 sensor dies, because it will
Use a 5-volt 2-bar GM map sensor plugged into the intake manifold, and run your "window" switch off that puppy. When the MAP sensor starts reading over (x) volts, start pumpin fuel. Of course, that voltage will end up equating so some amount of manifold pressure, so essentially you have a boost-dependant fuel source.
Much more reliable, although I still do not like 5th injector setups either way. I would much rather suggest you find a set of Tiburon injectors or something and strap on an S-AFC and dial the injectors down a bit...
Old Aug 12, 2002 | 05:32 AM
Red's Avatar
Red
Oooh, better idea. Cheuk will like this...
If you're aiming for low boost, just go pick up an adjustable rising rate fuel pressure regulator. In this case, it will make your life a lot easier than trying to fabricate something electronic, and will be cheaper than the injectors+safc part.
You'll still need a fuel pump that can deal with higher pressure tho...
Old Aug 12, 2002 | 07:13 AM
Lobert's Avatar
Red,
The 2k1 GL has the freaking returnless fuel system, so without replacing the whole system, I'm stuck trying to piece it together. That is until I can convince the ol'lady to allow me to do a Beta swap.
Old Aug 12, 2002 | 07:22 AM
Red's Avatar
Red
Welp, you get to install bigger injectors and an S-AFC then
Old Aug 12, 2002 | 10:19 AM
Lobert's Avatar
Red, what do you think of Greddy's Rebic III????? I think I can pick one up fairly cheaply.
