Engine ticking after oil change
What if you changed your oil and heard the ticking noise but it never went away. I think I have same problem but it only happens sometimes, and randomly it won't tick at all. But the ticks increase with rpm's just like Makij explained. Could it be HLA's and can they be replaced easily?
QUOTE (djshaggy)
My car makes that noise when I am low on oil.
It could also need a valve adjustment
You missed the point here on HLAs... they are so you do NOT have to adjust your valves...
QUOTE (Mad-Machine)
lol, haha....READ man!
So what do you suggest to get rid of my ticking noise? engine flush? inspect injectors 02.gif
if the noise has not gone away by now.. I am afraid you might need new lifters.. they are not too hard to replace.. but you do need to pull the cams... good time to install the 1.8 intake cam if that was on your agenda at all.
k, thanks...that's what I thought. Same thing happened on a T-bird I used to drive and I replaced lifters on that (so I have some knowledge...kind of).
I didn't have that on my agenda, don't know much about the mod. I drive a 1.8L tib so don't I have a 1.8L cam....
I know this is slightly off-topic, but I don't recommend changing your brand of oil unless you've got a good reason. However, I doubt that caused the ticking. Sounds like a valve/lifter problem.
