tibbytib |
09-18-2005 05:32 PM |
I'd say check your Throttle posistion Sensor. I had a bad hesitation problem in my 1986 Nissan Pickup and it turned out to be that sensor. Are you sure it's a clutch thing??? Drive your car and see if your car hesitates at differing positions of the throttle. My truck only hesitated at about 1/8 - 1/4 throttle. it wouldn't do it when I floored it, and it was most noticable when I let off the gas slowly from about 1/3 throttle to no throttle. From there, I knew it had something to do with the throttle. Cables looked good and tight, the only other thing it could have been was the TPS. Sure enough it was.
ALSO... when was the last time you had a tune up?? It may be as easy as replacing the wires and plugs. smile.gif
