Engine Buildup
Old Jul 7, 2001 | 03:06 PM
Lantra98's Avatar
Default Engine Buildup
Where do you start a engine buildup at when planning for a Turbo or Supercharger install... I want to make sure it's a smooth (future) install job...
Old Jul 8, 2001 | 07:16 AM
Give us a HP target first. 500 HP requires a much different buildup than 200 HP.
Old Jul 9, 2001 | 03:30 AM
Lantra98's Avatar
I'm thinking about putting 200HP on the street,nothing to crazy since i'm not trying to gun down a vette or viper "cough, cough" rolleyes.gif
But now seriously how your turbo doing, did you get any numbers from the dyno yet? That should make you 0-60 in Blurrr....
Old Jul 9, 2001 | 08:51 AM
for 200 HP to the wheels, you do not need to alter anything internally (Rods, pistions). Do you want to go NA, Supercharger or Turbo?
Old Jul 9, 2001 | 09:47 AM
YellowTiburon's Avatar
Vehicle: 2000 Tib
how much hp can you get from all of the N/A modafications avalible for the tiburons?
Old Jul 9, 2001 | 09:56 AM
Chueck in Korea stated that the highest NA tiburons are around 170 at the wheels or around 200 at the engine.
Old Jul 11, 2001 | 05:12 AM
Lantra98's Avatar
I want to keep the clean NA for daily driving, I want to get more info on the pros' and cons' of supercharging v.s. turbocharging maintanance overall "future costs minus the speeding tickets" hehehe smile.gif
Old Jul 11, 2001 | 06:46 AM
There are several links on the pros/cons
I will dig them up and throw them up here.
The biggest cons to Massive N/A HP is usually a lumpy idle
The biggest cons to Turbo are Massive heat in the engine compartment, and Turbo Lag
The biggest cons to Supercharging are Limited/impossible to intercool a manifold mount supercharger, and parasitic drag saps HP potentional.
Biggest PRO to N/A is usually bulletproof reliablilty
Biggest PRO to Turbo is MASSIVE HP potential.
Biggest PRo to Supercharging is Near N/A Reliability with Decent HP potential.
You should factor in Nitrous into your pros/cons list as well... Hell...this smells like an FAQ opportunity!
Old Jul 12, 2001 | 07:07 AM
Lantra98's Avatar
So how would the combination of Supercharger and Nitrous work in respect to total gains in HP???
Also what are the guess- stimate HP number I could expect with this tandem...
The heat issue sux on the supercharger but I guess I can deal with it, glad the bay area is no hot box...
Monday or Tuesday i'm going to my speed shop check out a supercharger install...
My mechanic is real cool he is a factory mechanic(GM,Nissan,Toyota)
