dual exhaust
Old Mar 25, 2002 | 06:38 AM
RiTibby's Avatar
Vehicle: 99 Tibby
Default dual exhaust
for people buying the cuda kits..with the dual exhaust tips..how would you be able to make it into an actual working dual exhaust cause i looked under my car today and it doesn't seem like you would be able to fit another pip on the drivers side of the car to the back..i may be wrong could someone clarify?
Old Mar 25, 2002 | 07:07 AM
totoro001's Avatar
i was wondering this too.. i mean it all seems like alot of 'uncle ben's' to me.. since it's a 1 sided engine.. but if someone has a good explanation for this, i'd be happy.
Old Mar 25, 2002 | 08:15 AM
Like most modern 4 and 6 cylinders that have 2 tailpipes and 2 mufflers......they split the exhaust into 2 seperate pipes right about the rear axle.
Look under an honda accord V6...you can see the "Y pipe right about the rear axle.
That is what you would have to do to a tibby to get dual exhaust.
Old Mar 25, 2002 | 09:23 AM
RiTibby's Avatar
Vehicle: 99 Tibby
thanks random..but where can the pipe go on the other side..it seems like the gas tank is more on that side and makes no room..
Old Mar 25, 2002 | 09:37 AM
Look again. The gas tank in under ther rear seat. That is the spare tire well, that is in the center. As far as "how" would you route it? I have no idea. Its not worth the time, trouble and expense to me...but then again...I don't have the cuda kit.
Old Mar 25, 2002 | 02:58 PM
Cuda-Turbo's Avatar
I do have the Cuda kit and will be getting it installed after Easter. I will let you guys know what I figure out for the exhaust when I have it done.
