Completely stumped and I'm desperate for help
Old Feb 17, 2014 | 10:30 AM
  #21
probably not.
i doubt more than an hour was spent diagnosing this entire problem.
Old Feb 17, 2014 | 04:10 PM
  #22
99x3beta's Avatar
Vehicle: 99/ Hyundai /accent
I don't have a obd and doesn't that only check sensors? I know every sensor is good
Old Feb 17, 2014 | 07:07 PM
  #23
pas1216's Avatar
Vehicle: 1991 Impulse RS
you KNOW every sensor is good? How so?
You're ready to give up and you haven't even tried to find/fix the problem. Get a code reader. Sometimes you can find them on the local used sites online or you can buy a cheap one from the auto parts store.
On my Isuzu I can use a jumper wire at the port and can actually read the codes off the dash light without a code reader. Not too sure if that can be done with a Hyundai or not.
Edit- Have you double checked all the grounds? One bad or unattached ground can prevent the car from starting.
Old Feb 18, 2014 | 02:14 AM
  #24
99x3beta's Avatar
I have 2 X3 and I used every sensor from my daily to see and it acted the same.
I'm going to find a code reader.
And my resistance is .3 it's normal and I'm not sure about disconnected grounds because I've been looking for that everytime I look at the car.
Old Feb 23, 2014 | 10:02 PM
  #25
99x3beta's Avatar
Question!!
If my fuel pump was starting to fail would it not give me the pressure I need for the injectors to fire?
I tested to see how much fuel would come out from the feed line. So I put the line in to a cup. And cranked the car for about 5-10 sec and I only got about an inch into the cup after doing that 2-3 times and this is a large Taco Bell cup btw.
It's a little fishy to me I feel like there should be a hell of a lot more fuel coming out then what I see. So in guessing low fuel pressure but what can cause that and could it be the fuel pump close to failure?
Thanks guys!
Old Feb 23, 2014 | 10:15 PM
  #26
volume and pressure arent the same thing.
seriously man if you arent gonna listen to ANYTHING we are sayin why bother asking?
Old Feb 24, 2014 | 08:48 AM
  #27
pas1216's Avatar
+100 ^^^^^^
Get a pressure gauge and hook it up to the line, find out how much pressure there is. Then take that info and go to your shop manual and compare the numbers. Is it low?
**** PLEASE tell me you have a shop/repair manual to work with?
large Taco Bell cup!? Guessing!?
Old Feb 24, 2014 | 10:30 AM
  #28
99x3beta's Avatar
so could that be a possibility???
and im sorry about the taco bell cup but thats all i had lol but it just seemed to me that the pressure would had to be low cause from all those cranks the cup should be atleast half full. and it should have what 40 psi right? ill find what pressure it has and get back to you guys.
and on the obd code reader....i told you guys ive changed all sensors with ones that i know worked obd only would tell me faulty sensors... no?
Old Feb 24, 2014 | 11:19 AM
  #29
volume DOESNT EQUAL PRESSURE
goddamit man READ WHAT I JUST TYPED
ok im gonna tell you exactly what to do
step 1: get a shop manual/access to a shop manual
step 2: learn how to use a multimeter
step 3: use shop manual to diagnose
step 4: profit
Old Feb 24, 2014 | 11:24 AM
  #30
pas1216's Avatar
I'm done.
