colt cams wont idle
Old Oct 26, 2010 | 09:15 AM
tib _500's Avatar
Default colt cams wont idle
anyone else have a problem with their idle hunting real bad after installing? i know these are cams and make the car run like a camed car, but i thought our ecus could relearn idle for the colt cam.
Old Oct 26, 2010 | 10:50 AM
tanc's Avatar
Vehicle: 1997 Tiburon
did you dial them in?
Old Oct 26, 2010 | 12:36 PM
The stock computer can only do so much. If you can drive a few driving cycles, does it throw a code?
Old Oct 26, 2010 | 01:49 PM
StrikeEagle's Avatar
I assume you reset your ECU?
Old Oct 26, 2010 | 07:04 PM
tib _500's Avatar
i had the idle problem before the cams. the cams made it a bit worse so i bumped the idle up. im debating replacing the ECU, or waiting and getting something like the mega squirt. with my current ECU the MAF circuits are messed up. it throws a MAF code with all the proper values on the ECU harness and on the MAF harness.
i was just curious if anyone has ran these cams on stock 2.0 ECU not Flashed or modified.
im not sure how to dial them in. i dont have an adjustable cam gear. i might wait to install them in my new engine until i get one, if i can run these with a stock ECU.
ive messed with SBC cams and distributors but.....
i was thinking the tiburon's was all elctronic besides adjusting the timing belt by a few teeth or the cam gear and risking bent valves
i found the original tread but red closed it before a conclusion was made, so any experience or help about this cam setup is appreciated
Old Oct 26, 2010 | 09:19 PM
It can be done satisfactorily, but modding a car with pre-existing problems is begging for trouble.
Old Oct 26, 2010 | 09:45 PM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
hey man i know its a drive for you to get to my house, but if you swing by i can help you fix the wiring for the maf.
Or any other problem you have.
Old Oct 26, 2010 | 10:19 PM
tib _500's Avatar
i got the wiring right now thanks to this but the comp throws the same code no matter what even if its unhooked and i used my volt meter to test continuity between the maf and ecu pin out.
once i get the new motor in we should have an ohio meet tho
Old Oct 26, 2010 | 10:28 PM
iheartmyrd's Avatar
i have another ecu if you wanted to give it a shot. let me check
i did a quick look but i couldnt find it, i found a tcm = P
