Clutch Problem
Old Feb 2, 2007 | 01:43 PM
Trancematic's Avatar
Hmm I have one for ya...
In friends 300ZX, getting off the freeway in 5th, go to downshift to 4th...
Push cluth in, second I moved clutch it pushed my foot off and fell to the floorboard mad.gif
Still had gears to hard shift but cluth pedal sits on floor, or with hand you can move it to resting position but once touched it falls to the floor.
EDIT (Mod move?)
*Prob should be moved to other vehicles since not a tib, my bad
Old Feb 2, 2007 | 01:49 PM
xxxmonoxidechild's Avatar
clutch is fine. either the slave cyl, or master cyl took a dump. just visually going over either should tell you whats wrong without even touching a tool.
Old Feb 2, 2007 | 01:51 PM
Aye, will go take a look
hamhead's Avatar
Ye I'd agree, probably since its an old car it just konked out. It happens.
Old Feb 2, 2007 | 01:56 PM
Its always something with this Z, being 17years old I can understand but like I said... always something
Old Feb 2, 2007 | 02:19 PM
dsrtibb's Avatar
Vehicle: 2001 tiburon
It might be the pressure plate not releasing. If its not the master/slave
Old Feb 2, 2007 | 02:24 PM
Well persay how can you tell if the master/slave cylinder is bad? There is no leaks and the level of fluid changes when you play with the pedal but once stopped, fluid then goes back up to normal.
Old Feb 2, 2007 | 10:35 PM
lilo shark's Avatar
that happen to me once, at the tracks. think how much that sucked!
