no no its the plastic bushings on the clutch pedal at the top and pull the master clutch cylinder if and see if it leaking mine did that befor it went out..
http://www.hyundaiaftermarket.com/noncgi/u...t=000062#000000 Go to HMA and get that TSB. Shows you how to do it. |
OK old post, arise and be alive again...
guys, I don't how I missed it, but I did it. I didn't get that TSB and now HA.com is no longer available; I do remember there was the part# for the new bushings listed... any of you can help with this PLEASE? |
I put up a TSB listing some time ago man.
And omfg! Hyundaiaftermarket.com is GONE!!! WOOHOO!!! |
I knew something like this was coming... I know HA.com is gone for a while, I just wanted to make a point that I had no other source of info than RDTib.com and in the searches I performed didn't come anything different than this, but I didn't think to search under TSB... genius ha? lmao.gif |
Hey guys, help would be appreciated; what I actually would need is the correct Part# for the "right" bushings to replace the defective bushings...
Please any of you that have this info.... (BTW; REDZ the info on the TSBs you had published on the site is not available). Thanks |
