View Poll Results: What clutch should i get?
XTD STAGE 3 Racing Clutch Kit
57.14%
F1 RACING STAGE 3 Clutch Kit
14.29%
OEM Clutch KIT
28.57%
OEM Heavy Duty Clutch Kit
0
0%
Voters: 7. You may not vote on this poll
Clutch?
Old May 12, 2005 | 12:27 PM
Ultra, it's not THAT big of a difference if you just get the clutch and not the whole kit.
Old May 12, 2005 | 12:29 PM
UltraTibby's Avatar
Thats true but if you factor in the price of getting your FW resurfaced or replaced else where you will probably end up at close to the same price for the whole VHR kit. Just a thought.
Old May 12, 2005 | 12:41 PM
hamhead's Avatar
Flywheel resurface = $50
Old May 12, 2005 | 08:57 PM
Agarwal's Avatar
I just got the F1 stage3 clutch. I'll install it (along with the new motor) in 3 weeks.
Old May 12, 2005 | 10:58 PM
OdessitPashka's Avatar
QUOTE (REDZMAN @ May 12 2005, 12:36 PM)
None of the above.
VHR Clutch.
I second that!
You can get just the clutch for the $300. If you are getting a turbo then you should understand that it's not going to be cheap and you need to be ready to spend some serious cash, so you should get in GB for stage 3 clutch.
Old May 13, 2005 | 07:04 AM
CyberShark's Avatar
YES, VHR!! I have it and am more then happy with it
Old May 13, 2005 | 04:27 PM
krazykyle's Avatar
btw how is the drivabilty with a 6 puck ive never drivin a car with one.
Old May 13, 2005 | 04:54 PM
hamhead's Avatar
Not too much worse... just grippy. Takes some getting used to, since the stock clutch is very lenient on misshifts. If you make a mistake, it'll bite hard and jerk ya a little. Kind of like revving to 3000RPM in first and letting off the gas.
Old May 13, 2005 | 08:23 PM
UltraTibby's Avatar
A little hard to get used to? That is an under statement. It is probably just a lot harder cause I did the lightened FW and clutch at the same time so you get a double wammy.
Old May 14, 2005 | 11:31 AM
Viper's Avatar
