Check Engine Light Has Been On...
i went to autozone and they did the free engine light check and got these codes
-P0455- Evaporative emission (EVAP) system“ large leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve
-P0734- Gear 4“ incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault
these are 2 out of the 3 codes that i got, forgot the other one. if anyone knows how to fix these so my car will pass inspection, please help.
you need to clean or replace purge solenoid. clean it first. i could never remember if it's the one by the evap canister or if there's another by the manifold. another thing is one of the tubes might be cracked or disconnected. the evap canister is located in the rear of the car around the trunk area by the gas tank.
there's a DIY made by hyundai on how to do it but i can't find it.
sorry but i can't find the DIY.
from redzman:
i agree, have your gas cap replaced with a brand new one and see if that fixes the problem, but only after you've visually inspected the condition of the tubes down there.
from redzman:
99% of the time it's a loose or improperly mounted gas cap.
