Changing Tranny Oil How?
Old Aug 6, 2005 | 06:54 PM
KayJai's Avatar
You'll need 2.2L of oil
The Hyundai Fill for Life MT-90 stuff is pretty good. Unless you've got a crazy setup engine wise, this is all you need.
Can't seem to paste the link from HMA, just create an account, then go to the "Shop" tab
CLick on Tib and your year
Click on trannys near the bottom
Click on Manual Tranny
Then there is a link to "Change your oil"
Or I'll cut and paste best I can
REPLACEMENT OF TRANSAXLE GEAR OIL
With the vehicle parked on a level surface, remove the drain plug and drain the transaxle oil.
Use HP Gear Oil SAE 75W/85W (API-GL 4)
Replace the gasket with a new one and install the drain plug.
TORQUE SPECIFICATION
Drain plug 30-35 Nm300-350 kg·cm22-25 lb·ft
Add new oil through the filler plug, filling to the same level as the plug opening.
MEASUREMENT SPECIFICATION
Transaxle oil total capacity: 2.15 lit2.27 qt1.89 impqt
Filler plug 30-35 Nm300-350 kg·cm22-25 lb·ft
Old Nov 14, 2005 | 02:47 PM
Alex01tib's Avatar
sorry to bring this up but im about to do this
it says replace the old gasket with a new one? ive never heard of a bolt requiring a gasket?
oh and should i listen to mad johns suggestion of 5-10 ftlbs or kayjai's of 22-25?
.............. /\ linky
Old Nov 15, 2005 | 03:09 PM
col96fx's Avatar
Vehicle: Hyosung GT650
The gasket is really a soft ally washer, and you should replace it if it looks squashed, but you prolly won't need to.
Old Nov 15, 2005 | 07:35 PM
Agarwal's Avatar
To fill the transmission with oil, you might want to use an oil transfer pump; it greatly helps and facilitates the task wink1.gif
Old Nov 15, 2005 | 07:56 PM
yes, unless you want to make a crazy assortment of funnels. the fill hole is at a really weird angle.
Old Nov 15, 2005 | 09:25 PM
Alex01tib's Avatar
/\ dont think thats goona be a problem look at the royal purple container, its like a squirt bottle. i got three quarts (came today :-)) and if it looks like its still gonna be hard, tho i dunno why, ill hop on the bus and go to autozone/walmart... thanks tho
Old Jul 31, 2007 | 08:29 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
Sorry to bump this with my noob questions - but how do you reach that drain plug? I don't see how you could reach it from above, but to reach it from below, I would need to jack up the car, but if I do that, the car won't be level as webtech says.
Also, is it easy to refill it directly from the Royal Purple bottle or should I buy that pump thingy (doesn't look like there's a lot of room there either)?
Thanks!
Old Jul 31, 2007 | 08:41 PM
LNHeart's Avatar
To drain the old oil you HAVE to jack it up. It has to be level when you are checking the level of the oil but not when you drain it. If i remember correctly, i think its a 19mm bolt.
To refill i always use a cone with a hose that come in a set. You can buy them at any local auto shop store.
Old Jul 31, 2007 | 08:57 PM
radu_rd2's Avatar
Cool, thanks a lot
Old Jul 31, 2007 | 08:59 PM
LNHeart's Avatar
