Buying Pulley with a Big System
Old Aug 26, 2002 | 10:59 PM
elantra101's Avatar
Default Buying Pulley with a Big System
How much would the crank pulley take away from my system if I want to put 4 tv's in my car with a playstation2 in it with 2 12's and all factory speakers redone? I know that alot of people say that they pulley will take away from the system or something like that. Is it smart not to go the pulley route if I have all of that in my car Some advice would be great before I get the pulley and it be the worst thing for me in the future
Old Aug 26, 2002 | 11:21 PM
JonGTR's Avatar
I wouldn't do it. The pulley has a noticeable affect on my headlights at idle with my stock system.
Old Aug 26, 2002 | 11:23 PM
elantra101's Avatar
Damn eek! , but how much difference do you feel fron before you installed the pulley?
Old Aug 26, 2002 | 11:28 PM
JonGTR's Avatar
I noticed a difference in performance, if that's what your asking. But, there is a difference in the A/C and electrical difference vs. stock. It's not enough for me to regret buying the pulley but I'm just not sure I would use it with a large system.
Old Aug 26, 2002 | 11:29 PM
elantra101's Avatar
Aiight cool thanks.
Old Aug 27, 2002 | 03:31 AM
Koreandude's Avatar
Well, you may want to run a larger battery and/or a larger alternator and some capacitors to help stabalize everything.
Old Aug 27, 2002 | 04:19 AM
JonGTR's Avatar
He may be right. I'm no electrical expert and I don't know anything about stereo equipment, I just know that it had a noticeable affect on my stock electrical system. tongue.gif I think this is a "one or the other" type of mod. The gains arent enough to get it while adding a considerable amount of weight to counteract its negative effects. Performance or sound system, you pick. wink
Old Aug 27, 2002 | 04:28 AM
more like, performance or HUGE system. If your headlights are already dimming when your subs hit, then you do NOT want an underdrive pulley. If you have less than maybe a 1000 watt system, you might not notice it.
***caution: numbers pulled from thin air***
Old Aug 27, 2002 | 04:33 AM
JonGTR's Avatar
I notice that my interior and exterior lights dim when at idle, and then brighten when I rev.
Old Aug 27, 2002 | 04:43 AM
Solo-Baric's Avatar
if you can get a smaller alternator pully it will offset it. but then would it offset the other pulley?
