Boring 101
Old Oct 22, 2001 | 10:08 AM
If you are going to be boring out your TB and the opening to your IM...you MIGHT be able to do this yourself...
The TB and IM opening should be bored out to 58mm if you are boring out a stock Tb. However, you now need to manufacture/create a new 58 MM throttle body butterfly. You need to create it within .5 MM tolerance, and you need to bore the TB out to 58 MM and it needs to be 100% true. If you are over .5MM off center you will punch through the wall of the TB.
In other words...I would not reccomend it, but you can try it. Just be prepared to buy a new TB if you mess it up.
