Big Bore Throttle Body
Old Jul 7, 2001 | 03:01 PM
plugboy's Avatar
Vehicle: 2000 Tiburon
Default Big Bore Throttle Body
How hard is it to put a Big Bore Throttle body on???? What would I have to do????
Old Jul 8, 2001 | 07:17 AM
I did an install FAQ for Fxtreme of the BTB and BIM. and I'll be doing a formal FAQ for TeamSR within 2 weeks. It is really a piece of cake. 4 bolts, and a couple of hoses.
Old Jul 8, 2001 | 08:08 AM
plugboy's Avatar
Cool get ahold of me when it's all writen up..
Old Aug 5, 2001 | 07:46 AM
Fast.Type-S's Avatar
Is it up yet? I'm curious of the install. wanna make sure I can do it before I buy it. Or think of getting it....Whichever...
Old Aug 5, 2001 | 10:55 AM
dj_dlrm's Avatar
but just take your time doing it you dont want to strip the screws holding the tps sensor
Old Aug 5, 2001 | 12:08 PM
2K3GT/2K Wagon's Avatar
Very easy mod to do.
Old Aug 5, 2001 | 02:37 PM
thespitefire's Avatar
Boring/Polishing the IM to match it in order to get the full gains is the hard (or at least tedious) part though tongue.gif
-Hans
Old Aug 5, 2001 | 03:12 PM
noticeable difference off the line there after? And what all is intailed in the install? Adn what tools are needed?
Old Aug 5, 2001 | 07:20 PM
Yes, better throttle response and more torque. Bradley registered 3.6 Hp and 3.x Torque (I cant remember exact torque figures) with a BTB and BIM. The BTB by itself won't do anything as the IM opening must be enlarged to match the BTB or all is for naught.
Remove throttle and cruise control cables.
Remove 4 bolts holding TB on
Remove 2 hoses under TB
Remove TPS from TB
Remove 1 of the 2 hoses, and connect the remaining hose to that connection, effective routing the coolant.
Install new TPS on new BTB
Install TB, tighten 4 bolts
Install Throttle and cruise cables.
You will have a phunky idle, Drive for 5 mintues, Let idle for 2 mintues, then adjust the idle control screw on the TB (drivers side closest to the firewall) if the idle is still high/low.
Old Aug 6, 2001 | 08:20 PM
Slipstream's Avatar
Okay, now I'm tempted. I won't be picking up a 'charger until probably after the warranty runs out or when I make enough money that I won't care. However, the new throttle body has been tempting me. I didn't realizze it offered more HP and torgue. I just read Improve throttle response and acceleration.
Course, now thinking about it...
