Beta 1 Intake manifold modification
Old Feb 18, 2020 | 06:55 PM
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
Default Beta 1 Intake manifold modification
I want to make more power on my NA Elantra. It's got Head work, high compression, reground cams ect. (6750 rpm limit still)
I guess my plan is to shorten the runners a bit and add some volume to the plenum. Still thinking about how I want to do it. If you have any advice or thoughts I would greatly appreciate it. I know the airram plenum is angled so it's taller on the side with the throttle body. Is this the way to go?
The only thing I've done is roughed in the inside of the plenum. Started knife edging the runners. Went through in a couple spots but that is easily fixed.
Between the tb and the first runner there are some vertical lines cast into the wall. It looks like it's only there to create turbulence. Perhaps to direct air away from the first runners for more even flow to the other cylinder, I guess, idk, I have no idea
Old Feb 18, 2020 | 06:56 PM
2000J25SP's Avatar
The opening is only 54mm. There's not much room to enlarge it. So I cut the flange off, either to reprepostition it farther from the edge or to replace it with a different flange/Throttle body.
Perhaps I could just add some rectangular pieces of aluminium in order to increase plenum volume.
Old Feb 19, 2020 | 11:48 PM
MaverickLC's Avatar
Vehicle: 2003/Hyundai/Coupe
About 12-13 years ago I tried the same thing… made new intake manifold from stainless steel, tried to copy AirRam, made it shorter with larger plenum and 2mm larger BBTB.
Made calculation using VE of the engine, compression, power etc. and power gains was so little… maybe I made wrong calculation and it was stock engine but it wasn’t worth the time and effort in my case
Old Feb 19, 2020 | 11:49 PM
MaverickLC's Avatar
MaverickLC's Avatar
Black line is with new intake manifold, red is stock manifold… (it was measured with G-tech back then), it was 2.0 Beta with 100kw (136HP).
Old Feb 20, 2020 | 07:21 PM
2000J25SP's Avatar
Awesome. Thank You for responding, great pictures, even a graph!
I'm sad that you didn't get more power after spending all that time making a whole manifold. I expected there would be a small loss in the low to mid range and a small gain up high. I guess not. It's weird the way power dropped like that after 6500rpm.
Old Feb 25, 2020 | 11:21 PM
MaverickLC's Avatar
It was demotivating… I had more expectations from that manifold
After that I turned to turbo and it changed my life lol
Old Feb 29, 2020 | 04:07 PM
2000J25SP's Avatar
I wanted to shorten the runners some but they are too close together to be able to weld all the way around without them leaking.
Old Mar 10, 2020 | 12:27 AM
MaverickLC's Avatar
Looks great
Old May 1, 2020 | 04:49 PM
2000J25SP's Avatar
Well it's been installed for a couple months now. I didn't do any real before and after testing, but the car does pull a bit harder up high now.
Related Topics
Thread
Forum
Replies
Last Post
dmg210
4
Apr 14, 2016 10:49 AM
popeye1
Engine, Intake, Exhaust
2
Dec 23, 2011 02:45 PM
David Dickson
For Sale
7
Apr 18, 2010 12:05 PM
MAXXTIB
Hyundai Tiburon Forum
54
Apr 18, 2008 02:58 PM
dwallace
10
Dec 11, 2006 08:26 AM
