Bad Motor Mounts? Help Please
Old Jul 10, 2008 | 11:00 PM
cleppe123456's Avatar
can bad motor mounts ruin a good new clutch and can then make a new clutch vibrate on enganement. i gotta a new clutch but i still have slippage and vibration when releasing the clutch in first gear... could it be motor oor tranny mounts or what else?>?>
Old Jul 10, 2008 | 11:48 PM
Footbstar251's Avatar
did you resurface the flywheel? I need to replace my front motor mount, and my new clutch also is slipping at 900 miles, so
idk if that can cause stress on the tranny I doubt it, but you should fix it either way.
Old Jul 10, 2008 | 11:52 PM
archsvile's Avatar
I've been getting weird vibrations lately also.. and when I did my clutch install i noticed my motor mounts were starting to dry rot. Also when I down shift my car vibrates (only when i down shift). Wondering if this is because of the motor mounts?
Old Jul 11, 2008 | 07:31 AM
Can you use the ENTER key and some different punctuation when you type?
You'll get more HELPFUL answers if you are more legible.
Old Jul 11, 2008 | 09:31 AM
tibbytib's Avatar
Be more specific on your problem. A vibration coming directly from your clutch pedal would definitely point to a problem that was not addressed when you changed your clutch. If it feels like the whole car is shaking, then there is a good possibility that one or more of the motor mounts needs replaced. I have diagnosed/replaced motor mounts on two vehicles, mine and a friends, and every time I ran across this problem, the vibrations seemed to shake the entire front end of the car.
Old Jul 11, 2008 | 10:07 AM
Mad_john's Avatar
no they wont blow you clutch but they will blow out your CV joints..
Old Jul 11, 2008 | 10:10 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
Does your steering wheel vibrate alot at idle?
Old Jul 11, 2008 | 10:50 AM
archsvile's Avatar
Yes I've been noticing that. lol to replace those can I just jack up the engine then take off the cross member or do I have to take out the cv joints and all that stuff? Or Dont I have to do any of that because of the tranny mount holding the engine up?
Old Jul 11, 2008 | 01:04 PM
yes the wheel does vibarte a lot at idle and when i let off the clutch the car still vibrates and i was figuring that the motor mounts were the reason for vibration maybe
matt
Old Jul 11, 2008 | 01:15 PM
QUOTE (RED ZMAN @ Jul 11 2008, 07:31 AM)
I take that as a NO then Matt?
Tell ya what, how bout you go ahead and do that, you have over 50 posts, you know the rules, umkay?
