Anyone ever use this ecu?
Vehicle: 1997 accent L
I was looking around Ray Hall's turbo site, and i came across another ecu there. Its called the Autronic SMC ecu, and it seems to be a pretty good setup. Any ideas? *looks in Red's and cheuk's direction*
That page you linked to only mentions Suby's and EVO's. You could try to contact them and see if they are willing to take on the Tiburon ECU. But since they are in AU, they will have the MAP equipped Tibby rather than the MAF equipped Engine.
Maybe Try Bry, and see if he knows of their reputation in OZ.
yes its is a MAP ECU http://www.turbofast.com.au/autronic/smcecu.html
Since you will change the whole ECU you can manage it with a MAP sensor instead of the MAF. The problem is that in the US you might not be able to drive your car with it?
Autronic, isn't that the SMC-5 that someone was selling on here earlier? Sounds familiar. I think it was essentially a combo AFC/ITC in one black box that is programmed with a laptop.
I have no reputable information pro or con on the unit.
