2nd 02 sensor
Old Aug 10, 2004 | 03:01 PM
cdogtibby1's Avatar
Default Re: Tibfest 2004
I HAD A CAT INSTALLED MAN..... still got my CEL.
wattsup4800's Avatar
Default Re: 2nd 02 sensor
dude make sure that all 02 sensors are properly installed
remember my car didnt idle?
other then that it didnt change anything, but my air fuel ratio was very bad.
i found out my car is running lean
Old Aug 11, 2004 | 01:27 PM
kidwell03's Avatar
Default Re: The Elantra is DONE
Well thanks for the replies. I went ahead and bought a catco hiflow cat, and I will install the o2 sensor after the cat. Hopefully I won't get a cel.
Old Aug 11, 2004 | 01:31 PM
Default Re: Horse power gain and overal
where is the 1st o2 sensor located?
Old Aug 11, 2004 | 01:36 PM
cdogtibby1's Avatar
well... its under the heat shield on your manifold... plugs in right there on the right side... ya cant miss it dude.
BTW: i just got my code read at autozone... something about a catalyst above threshold... whatever the hell that means, not to but does anyone wanna try and help me with this... he also told me that he thought it was the first sensor?!?!
Old Aug 11, 2004 | 01:57 PM
where is the heat shield
remember i have 421 headers
and no cat
Old Aug 11, 2004 | 02:04 PM
The_Alpha_Male's Avatar
if you have headers, your heat shield should be gone
Old Aug 11, 2004 | 02:08 PM
cdogtibby1's Avatar
Default Re: LEDs
ook... headers.... its on the 4th pipe... left to right it goes 1234... its on the one on the furthest right. it sticks right out of the dern pipe mang... unless you didnt have that 02 bung... if you didnt, you may not even have the damn thing installed on the header. better get to lookin around.
Old Aug 11, 2004 | 02:14 PM
Default Re: speedvision gauges
yea i definitly think i dont have that b*tch installed
would an o2 bung work if not what would
Old Aug 18, 2004 | 02:29 AM
Default Re: Insomniac Thread
you're gonna' have to do the same thing that i'm stuck with.
when you get your exhaust done, have them make a second O2 sensor bung after your cat where their first pipe is gonna' be. the ORIGINAL 2nd bung (the one on the flex pipe) is going to be your money spot for sensor #1, but you'll have to get the wires to BOTH sensors lengthened more to make this work.
hope that helps
