EDI Performance
Sponsor:  EDI Performance
EDI Performance strives to provide outstanding customer service. We are here to help you find that must have part while staying on budget!
http://www.EDIperformance.com
AEM Wideband Gauge Blowout!
Old Jan 4, 2012 | 08:17 AM
Ken@EDI Performance's Avatar
Vehicle: 2010 Hyundai Genesis Coupe 2.0T
Default AEM Wideband Gauge Blowout!
AEM Digital Wideband UEGO Gauge: A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM's Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED needle that changes colors as AFR changes from rich to lean. The units 52mm (2-1/16) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
* Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
* Does not oscillate AFR reading like narrow band sensors
* No laptop required for monitoring!
* Bosch sensor included
* Accurate to 0.1 AFR
* Reads in AFR or Lambda via a switch in back of gauge housing
* 24 Color-coded LED display lights provide immediate reference to engines air/fuel ratio (AFR) or Lambda ratio
* Integrated three-digit display reveals AFR or Lambda in real time
* User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
* Serial data stream included for output of AFR (RS 232)
Retail: $277.50
PM for pricing... Its much lower than I can legally advertise!!!
