Safc Wiring *28 March 2007
Old Aug 27, 2006 | 10:12 AM
  #21
That's a Version 2.
I'd go to Apexi's website and get the manual. Make sure everything is connected properly to the proper wires. Sometimes, supposedly, Hyundai used different wiring coloring throughout our cars, so if you attached wires via color matching, you may have screwed yourself. You need to do it by following the wires from the ECU/Plug.
The Version 2 has a Knock sensor, that's the extra wires, might wanna hook them up.
Old Aug 27, 2006 | 10:20 AM
  #22
B00stedTib's Avatar
no i still have 3 extra wires after i hook up the knock sensor...a blue one, an orange one, and another color..cant remember.
ill go back after it cools down...(texas its 107 in houston right now) and check the wiring diagrams and installation booklet that came with the package when i bought it just to make sure...but something just seems wierd. its almost like my spark plugs arent sparkn(which will be the next thing i check) and if they are then i know its a fuel issue and ill figure out where the issue is...because my car worked fine right b4 i didn the install so it shouldnt have any problems after....... 02.gif
i didnt go by hyundai wire color i went by pin on the ecu plug.
when i go back out there around 4-5 then ill snap some pics of all the extra wires im talking about and show you my setup.
Old Aug 27, 2006 | 11:33 AM
  #23
can you hear the ignition coil buzzing when you turn the key?
Old Aug 27, 2006 | 11:36 AM
  #24
B00stedTib's Avatar
not sure...i mean when i crank it....its like rararararararara.....like its turning but either the spark or the the fuel isnt gettn there to start the combustion.
unfortunatly its POURING outside now so i cant go work on it. but as soon as i can im gonna go back and pull and plug and and wire and see if i get a spark on it or not.
if i do then i know its fuel related...but im almost positive its gotta be something with the SAFC because my car worked fine before i did the install.
Old Aug 27, 2006 | 01:03 PM
  #25
B00stedTib's Avatar
sry...i post on 3 different forums...sometimes i get them all confused on how they want stuff posted
but on the other side redz...do you have any idea what might be going on...and what these extra 3 wires are that come out of the wiring harness for the Super AFC 2
im without a car right now so im in desperate help....
thanks in advance guys
Old Aug 27, 2006 | 01:08 PM
  #26
put the key in the ignition position, and listen for a buz with your hood open.
Old Aug 27, 2006 | 02:06 PM
  #27
B00stedTib's Avatar
no buzz when i turn the key to the on position...what do i need to replace? lolz
Old Aug 27, 2006 | 04:55 PM
  #28
nothing. you probably didnt break anything. you could have popped a fuse. i really dont know. post up a link for the directions for the SAFC and i can help you out with where to connect everything.
Old Aug 27, 2006 | 06:33 PM
  #29
check the ignition fuse in the engine bay fuse box too.
