Need To Convert Something?
Okay, I've used another version of this site for some time now, and found this MUCH cleaner, ADD FREE version of it.
http://www.unitconversion.org/
Here you can convert just about any measurement of ANYTHING, into any other format, instantly.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Common converters
Distance and Length Conversion (92)
meter, kilometer, decimeter, centimeter, millimeter, micron, league, mile, fathom, yard, foot, inch, microinch, caliber, megameter ...
Weight and Mass Conversion (70)
kilogram, gram, kilopound, slug, pound, ounce, quintal, stone, tonne, pennyweight, carat, grain, talent, mina, Planck mass ...
Currency Conversion (36)
US Dollar, Euro, British Pound, Canadian Dollar, Australian Dollar, Japanese Yen, New Zealand Dollar, Switzerland Franc ...
Capacity and Volume Conversion (76)
cubic meter, cubic kilometer, cubic decimeter, cubic centimeter, cubic millimeter, liter, exaliter, petaliter, teraliter ...
Volume - Dry Conversion (15)
liter, barrel dry, pint dry, quart dry, peck, bushel, cor, homer, ephah, seah, omer, cab, log ...
Temperature Conversion (6)
kelvin, degree Celsius, degree Fahrenheit, degree Rankine, degree Reaumur, Triple point of water
Area Conversion (39)
square meter, square kilometer, square hectometer, square dekameter, square decimeter, square centimeter, square millimeter ...
Pressure Conversion (52)
pascal, bar, pound-force/square inch, torr, atmosphere technical, Standard atmosphere, gigapascal, megapascal, hectopascal ...
Energy and Work Conversion (54)
joule, gigajoule, megajoule, kilojoule, millijoule, microjoule, nanojoule, attojoule, megaelectron-volt, kiloelectron-volt ...
Power Conversion (76)
watt, exawatt, petawatt, terawatt, gigawatt, megawatt, kilowatt, hectowatt, dekawatt, deciwatt, centiwatt, milliwatt, microwatt ...
Force Conversion (33)
newton, exanewton, petanewton, teranewton, giganewton, meganewton, kilonewton, hectonewton, dekanewton, decinewton, centinewton ...
Time Conversion (33)
second, millisecond, microsecond, nanosecond, picosecond, femtosecond, attosecond, shake, minute, hour, day, week, month, year ...
Velocity Conversion (32)
meter/second, meter/hour, meter/minute, kilometer/hour, kilometer/minute, kilometer/second, centimeter/hour, centimeter/minute ...
Angle Conversion (14)
degree, radian, grad, gon, minute, second, sign, mil, revolution, circle, turn, quadrant, right angle, sextant
Fuel Consumption Conversion (37)
meter/liter, exameter/liter, petameter/liter, terameter/liter, gigameter/liter, megameter/liter, kilometer/liter, hectometer/liter ...
Numbers Conversion (39)
binary, octal, decimal, hexadecimal, base-2, base-3, base-4, base-5, base-6, base-7, base-8, base-9, base-10, base-11, base-12 ...
Data Storage Conversion (41)
bit, nibble, byte, character, word, MAPM-word, quadruple-word, block, kilobit, kilobyte, megabit, megabyte, gigabit, gigabyte ...
Engineering converters
Velocity - Angular Conversion (12)
radian/second, radian/day, radian/hour, radian/minute, degree/day, degree/hour, degree/minute, degree/second, revolution/day ...
Acceleration Conversion (19)
decimeter/square second, meter/square second, kilometer/square second, hectometer/square second, dekameter/square second ...
Acceleration - Angular Conversion (5)
radian/square second, radian/square minute, revolution/square second, revolution/minute/second, revolution/square minute
Density Conversion (42)
kilogram/cubic meter, kilogram/cubic centimeter, gram/cubic meter, gram/cubic centimeter, gram/cubic millimeter ...
Specific Volume Conversion (8)
cubic meter/kilogram, cubic centimeter/gram, liter/kilogram, liter/gram, cubic foot/kilogram, cubic foot/pound, gallon/pound ...
Moment of Inertia Conversion (14)
kilogram square meter, kilogram square centimeter, kilogram square millimeter, gram square centimeter, gram square millimeter ...
Moment of Force Conversion (12)
newton meter, kilonewton meter, millinewton meter, micronewton meter, ton-force meter, kilogram-force meter, gram-force centimeter ...
Torque Conversion (17)
newton meter, newton centimeter, newton millimeter, kilonewton meter, dyne meter, dyne centimeter, dyne millimeter ...
Heat converters
Fuel Efficiency - Mass Conversion (15)
joule/kilogram, kilojoule/kilogram, calorie/gram, Btu/pound, kilogram/joule, kilogram/kilojoule, gram/calorie, pound/Btu ...
Fuel Efficiency - Volume Conversion (15)
joule/cubic meter, joule/liter, megajoule/cubic meter, kilojoule/cubic meter, kilocalorie/cubic meter, calorie/cubic centimeter ...
Temperature Interval Conversion (6)
kelvin, degree Celsius, degree centigrade, degree Fahrenheit, degree Rankine, degree Reaumur
Thermal Expansion Conversion (5)
length/length/kelvin, length/length/degree Celsius, length/length/degree Fahrenheit, length/length/degree Rankine ...
Thermal Resistance Conversion (5)
kelvin/watt, degree Fahrenheit hour/Btu, degree Fahrenheit second/Btu ...
Thermal Conductivity Conversion (13)
watt/meter/K, watt/centimeter/テつーC, kilowatt/meter/K, calorie/second/centimeter/テつーC, kilocalorie/hour/meter/テつーC ...
Specific Heat Capacity Conversion (20)
joule/kilogram/K, joule/kilogram/テつーC, joule/gram/テつーC, kilojoule/kilogram/K, kilojoule/kilogram/テつーC, calorie/gram/テつーC, calorie/gram/テつーF ...
Heat Density Conversion (5)
joule/square meter, calorie/square centimeter, langley, Btu/square foot ...
Heat Flux Density Conversion (26)
watt/square meter, kilowatt/square meter, watt/square centimeter, watt/square inch, joule/second/square meter ...
Heat Transfer Coefficient Conversion (11)
watt/square meter/K, watt/square meter/テつーC, joule/second/square meter/K, calorie/second/square centimeter/テつーC ...
Fluids converters
Flow Conversion (58)
cubic meter/second, cubic meter/day, cubic meter/hour, cubic meter/minute, cubic centimeter/day, cubic centimeter/hour ...
Flow - Mass Conversion (31)
kilogram/second, gram/second, gram/minute, gram/hour, gram/day, milligram/minute, milligram/hour, milligram/day, kilogram/minute ...
Flow - Molar Conversion (26)
mol/second, examol/second, petamol/second, teramol/second, gigamol/second, megamol/second, kilomol/second, hectomol/second ...
Mass Flux Density Conversion (7)
gram/second/square meter, kilogram/hour/square meter, kilogram/hour/square foot, kilogram/second/square meter ...
Concentration - Molar Conversion (12)
mol/cubic meter, mol/liter, mol/cubic centimeter, mol/cubic millimeter, kilomol/cubic meter, kilomol/liter ...
Concentration - Solution Conversion (11)
kilogram/liter, gram/liter, milligram/liter, part/million, grain/gallon, pound/gallon, pound/million gallon, pound/cubic foot ...
Viscosity - Dynamic Conversion (29)
pascal second, kilogram-force second/square meter, newton second/square meter, millinewton second/square meter ...
Viscosity - Kinematic Conversion (24)
square meter/second, square meter/hour, square centimeter/second, square millimeter/second, square foot/second, square foot/hour ...
Surface Tension Conversion (8)
newton/meter, millinewnon/meter, gram-force/centimeter, dyne/centimeter, erg/square centimeter, erg/square millimeter ...
Permeability Conversion (5)
kilogram/pascal/second/square meter, permeability, permeability inches ...
Sound converters
Sound Conversion (3)
bel, decibel, neper
Light converters
Luminance Conversion (19)
candela/square meter, candela/square centimeter, candela/square foot, candela/square inch, kilocandela/square meter, stilb ...
Luminous Intensity Conversion (10)
candle, decimal candle, pentane candle, hefner candle, carcel unit, bougie decimal, lumen/steradian ...
Illumination Conversion (12)
lux, meter-candle, centimeter-candle, foot-candle, flame, phot, nox, candela steradian/square meter, lumen/square meter ...
Digital Image Resolution Conversion (4)
dot/meter, dot/millimeter, dot/inch, pixel/inch
Frequency Wavelength Conversion (34)
hertz, exahertz, petahertz, terahertz, gigahertz, megahertz, kilohertz, hectohertz, dekahertz, decihertz, centihertz, millihertz ...
Electricity converters
Charge Conversion (17)
coulomb, megacoulomb, kilocoulomb, millicoulomb, microcoulomb, nanocoulomb, picocoulomb, abcoulomb, EMU of charge, statcoulomb ...
Linear Charge Density Conversion (6)
coulomb/meter, coulomb/centimeter, coulomb/inch, abcoulomb/meter, abcoulomb/centimeter, abcoulomb/inch
Surface Charge Density Conversion (6)
coulomb/square meter, coulomb/square centimeter, coulomb/square inch, abcoulomb/square meter, abcoulomb/square centimeter ...
Volume Charge Density Conversion (6)
coulomb/cubic meter, coulomb/cubic centimeter, coulomb/cubic inch, abcoulomb/cubic meter, abcoulomb/cubic centimeter ...
Current Conversion (10)
ampere, kiloampere, milliampere, biot, abampere, EMU of current, statampere, ESU of current, CGS e.m. unit, CGS e.s. unit
Linear Current Density Conversion (8)
ampere/meter, ampere/centimeter, ampere/inch, abampere/meter, abampere/centimeter, abampere/inch, oersted, gilbert/centimeter
Surface Current Density Conversion (6)
ampere/square meter, ampere/square centimeter, ampere/square inch, ampere/square mil, ampere/cicular mil ...
Electric Field Strength Conversion (13)
volt/meter, kilovolt/meter, kilovolt/centimeter, volt/centimeter, millivolt/meter, microvolt/meter, kilovolt/inch, volt/inch ...
Electric Potential Conversion (6)
volt, watt/ampere, abvolt, EMU of electric potential, statvolt, ESU of electric potential
Electric Resistance Conversion (10)
ohm, megohm, microhm, volt/ampere, reciprocal siemens, abohm, EMU of resistance, statohm, ESU of resistance ...
Electric Resistivity Conversion (8)
ohm meter, ohm centimeter, ohm inch, microhm centimeter, microhm inch, abohm centimeter, statohm centimeter, circular mil ohm/foot
Electric Conductance Conversion (12)
siemens, megasiemens, kilosiemens, millisiemens, microsiemens, ampere/volt, mho, gemmho, micromho, abmho, statmho ...
Electric Conductivity Conversion (8)
siemens/meter, picosiemens/meter, mho/meter, mho/centimeter, abmho/meter, abmho/centimeter, statmho/meter, statmho/centimeter
Electrostatic Capacitance Conversion (22)
farad, exafarad, petafarad, terafarad, gigafarad, megafarad, kilofarad, hectofarad, dekafarad, decifarad, centifarad, millifarad ...
Inductance Conversion (22)
henry, exahenry, petahenry, terahenry, gigahenry, megahenry, kilohenry, hectohenry, dekahenry, decihenry, centihenry, millihenry ...
Magnetism converters
Magnetomotive Force Conversion (5)
ampere turn, kiloampere turn, milliampere turn, abampere turn, gilbert
Magnetic Field Strength Conversion (4)
ampere/meter, ampere turn/meter, kiloampere/meter, oersted
Magnetic Flux Conversion (13)
weber, milliweber, microweber, volt second, unit pole, megaline, kiloline, line, maxwell, tesla square meter ...
Magnetic Flux Density Conversion (11)
tesla, weber/square meter, weber/square centimeter, weber/square inch, maxwell/square meter, maxwell/square centimeter ...
Radiology converters
Radiation Conversion (22)
gray/second, exagray/second, petagray/second, teragray/second, gigagray/second, megagray/second, kilogray/second, hectogray/second ...
Radiation - Activity Conversion (16)
becquerel, terabecquerel, gigabecquerel, megabecquerel, kilobecquerel, millibecquerel, curie, kilocurie, millicurie, microcurie ...
Radiation - Exposure Conversion (7)
coulomb/kilogram, millicoulomb/kilogram, microcoulomb/kilogram, roentgen, tissue roentgen, parker, rep
Radiation - Absorbed Dose Conversion (23)
rad, millirad, joule/kilogram, joule/gram, joule/centigram, joule/milligram, gray, exagray, petagray, teragray, gigagray, megagray ...
Miscellaneous converters
Prefixes Conversion (21)
none, yotta, zetta, exa, peta, tera, giga, mega, kilo, hecto, deka, deci, centi, milli, micro, nano, pico, femto, atto, zepto ...
Data Transfer Conversion (107)
bit/second, byte/second, kilobit/second, kilobyte/second, megabit/second, megabyte/second, gigabit/second, gigabyte/second ...
EU Currency Conversion (12)
Euro, Irish Pound, Deutsch Mark, Dutch Guilden, Finnish Mark, French Franc, Austrian Schilling, Belgian Franc, Luxembourg Franc ...
Typography Conversion (15)
twip, meter, centimeter, millimeter, character, pixel, inch, pica, PostScript point, point, en ...
Volume - Lumber Conversion (17)
cubic meter, cubic foot, cubic inch, board feet, thousand board feet, cord, cord feet, cunit, pallet, cross tie, switch tie ...</div>
I told you there are a LOT of them on that site.
This is the sister site of www.convert-me.com , which I prefer, because you can just put in the quantity you want converted, hit enter, and you get all the conversions on ONE page for that type of measurement (length, ect).
So why did I post this?
Do you have a Standard socket set and need to know what the Metric equivalent is? Wanting to convert metric HP measurements to US measurements? Miles to meters? Won to USD? Resistance for LED projects?
Check it out. Almost overwhelming.
Heat converters
Fluids converters
Sound converters
bel, decibel, neper
Light converters
definitely very extensive. Good find.
For simple stuff, I just use Google.
Search for:
2.2 liters to ounces
or
86 fahrenheit to celsius
Google Returns:
2.2 liters = 74.3908496 US fluid ounces
or
86 degrees Fahrenheit = 30 degrees Celsius
Search for:
or
Google Returns:
or
The guy that runs the site signed up here, I'm assuming by checking to see where the new traffic was coming from. He saw that I was interested in Tables, so he did them.
Each link on that main page, if you click it, has a LINK at the bottom of the page that says...
<div class='quotetop'>QUOTE </div><div class='quotemain'>Looking for an interactive distance and length conversion table?</div>
Click on that, and you are set.
Very friggin nice site, I love that stuff.
If ya'll want, I can install some of these converters here on our site.
Which ones would everyone want?
that is an awesome site.
I think functionality of a Currency Converter (for dealing with CAD and our friends in Greece) would be good for the site.
Dang... 8000k = 13,940.33ツコF ???
I'm not smart enough to be able to use 98% of those
