LED & Speakers...
Old Jul 29, 2004 | 08:39 PM
Guardian262's Avatar
Default Re: Members
sweet lighting brother. Just the past week I saw some speakers in the crutchfield mag with LED's built in. They were from a company I havent heard of before so I already started thinking about how to make mine glow. Looks like you saved me a bunch of thinking, I dont have much to spare anyway.
Kinda curious about how you have your amps mounted. Seems that they wouldnt disappate heat very well with the back seats in the upright position. You had any problems with them overheating? If not, looks like a great space saver to me.
Old Jul 29, 2004 | 10:45 PM
Default Re: Airram Guys, Hold up! Hondata Heatshield Gakets AVAILAB
Wow wow and wow.
First member I've ever seen from Italy too.
Good one man, I may have to do that instead of speaker haloz.
Old Jul 30, 2004 | 06:43 AM
tibwrcsbj's Avatar
Default Re: BETA vs 4g63
^^loser.....Im going to do BOTH.....hehe
Old Aug 3, 2004 | 04:33 PM
Blu_Drgn's Avatar
From: Lillington, NC & Maryville, TN when I can get there
Default Re: Screw in rear rotor?
Okay, maybe i'm just out of the loop here or something but where can you those pioneer grills at (or something like them) my grills are different you cant see through them at all even if i was to put leds in them. does anyone know where i could get some?
Old Sep 22, 2004 | 07:11 PM
Blu_Drgn's Avatar
Default Re: CUDA body kit
bump for info
Old Sep 23, 2004 | 06:19 AM
Mr_Hyde_NT's Avatar
Default Re: Get a free Ipod!!!
well, if you are meanign my work, i only got the Pioneer oval patch by the original 6*9 Pioneer grills in bundle with the speaker set, so i glued them on the original tiburon grill... easy...
never seen official "pioneer" grills.. mine is just a handmade work.. wink1.gif
Old Sep 23, 2004 | 08:45 AM
Blu_Drgn's Avatar
Default fs:stock fog lights
oh ok thanks
Old Sep 23, 2004 | 09:32 AM
tibwrcsbj's Avatar
Default Re: Lower ball joint
blu, there is also a peice of grille CLOTH behind the grills.....removing this would make the grilles look like the ones above. (minus the pioneer badge, of course)
Old Sep 23, 2004 | 10:33 AM
MADTIB's Avatar
Default Re: Exhaust Help
<div class='quotetop'>QUOTE </div><div class='quotemain'>Kinda curious about how you have your amps mounted. Seems that they wouldnt disappate heat very well with the back seats in the upright position. You had any problems with them overheating? If not, looks like a great space saver to me.</div>
Actually,amps dissapate heat much better when they are mounted vertically rather then horizontally.
Old Oct 6, 2004 | 07:16 PM
redturbulance's Avatar
Vehicle: 2001 Hyundai tiburon
Default Re: My Show Winner
I had a couple of questions about the wireing....i'm really bad at figuring this out initially but.....you just put the resistor in between each one and wired them all together and then one side of the wireing was ground and the other was positive correct.
Example
+side----led---resistor----led----resistor---led---ground
Is this correct....Also white leds are hella expensive at radio shack....5 bucks a piece.....i have to buy them somewhere else
