Dimmer Switch DIY (RD2)
Skill level (out of 5): 3 Time taken: 30 minutes Tools needed: Small flathead screwdriver Soldering gun and supplies 5mm LED of preferred color Resistor (I used 430 ohm) 1. Remove dimmer switch with a flathead screwdriver https://i75.photobucket.com/albums/i...Y/IMG_7863.jpg 2. Unplug power https://i75.photobucket.com/albums/i...Y/IMG_7865.jpg 3. Note which one is ground and power https://i75.photobucket.com/albums/i...Y/IMG_7868.jpg 4. Remove face of switch with screwdriver. There’s two little clip things on either side, get one side loose and the other one comes right off. https://i75.photobucket.com/albums/i...Y/IMG_7871.jpg 5. Remove circuit board by first getting the wheel out of its socket. Either use the screwdriver or a little force by hand to dislodge the wheel. https://i75.photobucket.com/albums/i...Y/IMG_7873.jpg 6. Remove board https://i75.photobucket.com/albums/i...Y/IMG_7874.jpg 7. LED will need to point towards the white, so take note of how it should be in place. https://i75.photobucket.com/albums/i...Y/IMG_7875.jpg 8. Shave LED a little bit. Not too much or the spread is too wide and you won’t notice it. 9. Solder negative LED to the top post, and the positive to the one below it (with a resistor). Do NOT solder it to the large one closer to the wheel (as I did the first time…) The power on that one is variable, and opposite of the dial. E.G if you have the dimmer all the way bright, the LED will be off, but if the dimmer is all the way dim, the LED is very bright. Backwards of how you’d want it. So be sure to do it as shown in the picture. https://i75.photobucket.com/albums/i...Y/IMG_7883.jpg 10. Reinstall circuit board and test if it works. https://i75.photobucket.com/albums/i...Y/IMG_7881.jpg 11. Put face back on and reinstall! https://i75.photobucket.com/albums/i...Y/IMG_7881.jpg There is a little much blue coming through the rest of the black instead of just through the white, but there’s no way to avoid that. You could try painting the inside a little with white out, but then it might not show through the white. |
good diy mang!
nice. i have like 80 white leds left and i need to find things to do.
thanks for more places to put leds!! |
I love putting LEDs anywhere I can. I just got 500 of them in the mail wink1.gif
DTN, you going to add this one to your and Tibby01's DIY? |
It's kind of a seperate DIY in itself. All the LEDs in the dash DIY were replacements for those white with a blue condom stockers. This is not a light modification, it's actually a light creation. I think it should be it's own DIY. I did mention this at the end of the heater/switches DIY, but i didn't put pictures. I'll put a link referring to this page on that DIY.
I did notice a difference in your dimmer to mine. I have 3 diodes called D1, D2 and D3, i noticed you only have D3 showing. D1+D2 are next to D3 on mine. |
^^^ Ah, gotcha.
Not quite sure which diodes you're referring to, but I think it's over my head tongue.gif |
^^ Oops. I misread it. if you look at the ciruit, next to the rotating dimmer wheel, you can see a black object and printed on the circuit board is "D1". Mine has D2 and D3 as well. Yours does not. In one shot, it shows the diode, and above it is the number 3, but to the right is "D1"
Also, i run a LED which is shaved flat on mine, it works just fine. |
I added an LED to mine too. My switch is slightly different. There were two small holes in the board right at the front, meant for a bulb. I just popped an LED in and bent it 90 degrees forward, and added a few drops of solder.
http://mywebpages.comcast.net/vsluit.../dimswitch.jpg |
the newer switch style has 3 diodes labeled D1, D2 and D3. I had the modification performed at the dealership under warranty as per the TSB on slightly flickering lights at full brightness.
https://i45.photobucket.com/albums/f...ledondiode.jpg
This is the TSB replacement part board for the "lights flicker when on full brightness". The picture shows how to hook up the LEDs on the newest style board. |
| All times are GMT -6. The time now is 04:59 AM. |
