LC2 Remote Starter + Alarm Installation, Wiring Colors, + Notes of location
By f0rbidden
Hyundai || Accent || 2003 - 2003
Remote Starter Wiring Colors and Notes
Function Vehicle Color Location
Start: White (+)
Ignition #1: Green (+) Ignition switch harness
Ignition #2: N/A Ignition switch harness
Ignition #3: N/A Ignition switch harness
Accessory: Yellow (+) Ignition switch harness
Brake Light: Pink/Black (+) Brake pedal switch
Tach Signal: Gray (AC) ECM under drivers side of the dash
Parking Lights: Grn/Org (L) & Grn/Blk ® (+) Drivers kick panel
Headlights: N/A
Diesel Glow Plug: N/A
Clutch Bypass Wire: N/A
Notes:
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts: Red (+) Ignition switch harness
OEM Alarm Disarm: N/A
OEM Horn: Blue/Orange (-) Steering column harness
Power Lock: Black/Orange (-) ETACS module to the left of the steering column.**
Power Unlock: Yellow (-) ETACS module to the left of the steering column.
Trunk Release: N/A
Alarm Input Wire: Green (-) Drivers kick panel or cluster
PARKING LIGHTS GREEN/ORANGE (L) AND GREEN/BLACK ® (+) DRIVERS KICK PANEL
DOMELIGHT GREEN (-) DRIVERS KICK PANEL
Start: White (+)
Headlights: N/A
Notes:
Trunk Release: N/A
