Duplicolor Wheel Paint sorta DIY
Old Oct 29, 2004 | 03:54 PM
javageek's Avatar
Default Re: where can i find a cheap turbo
That's the stuff I painted my dash with. Works like a charm.
Old Oct 31, 2004 | 08:38 AM
Dweet's Avatar
Default Re: clock lense..
so you used wheel paint to do your interior? im going to redo mine monday.. too many scratches...
Old Jun 26, 2007 | 09:42 PM
chacho_1986's Avatar
I just painted mine too and they look fantastic. I decided to only paint the spokes gloss black to match my exterior and used dupli-color high temp engine enamel (500 degree) and some clear coat. also dupli-color engine primer of course. then just masked off the parts i didn't want colored with masking tape and a razor blade and went to town on it. I took the wheels off and did all this too. seemed like less work than to have to go back and re-paint my calipers and such.
As far as the interior work goes, dupli-color makes a special vinyl paint that works great for tib's, esp rd1's and rd2's because they have very little fabric. the newer ones have all that fabric all over the door panels. you might could wanna check that out before throwing wheel paint on your interior. it might all turn out looking like completely untextured plastic.
Old Jun 26, 2007 | 09:52 PM
I did mine in 2 tone with the same stuff.
1.put a bag on the whole tire
2.use tape to secure it to the tire.
3.tape off the area you don't want to paint
4. spray the paint over the tape and the are you want painted
5. remove the tape when the paint is wet
6. wait 3 hours for the paint to dry
7. tape off the area you already painted
8. spray over the area you want painted and the tape
9. remove the tape
10. clearcoat over the whole thing.
These pix are pretty old and i'll probly never get to post them again.
Old Jun 27, 2007 | 07:51 PM
KustomizedTiburon's Avatar
Hell yea, looks good DTN!!
Old Jun 27, 2007 | 10:15 PM
^^ Thanks.. Kinda makes me wish I still had those bad boys. I did like the stockers better then the ones I have now, but i bent a stock rim.
Old Jun 28, 2007 | 05:09 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
wow! i actually really really like those. as kevin arnold would say " i like them like them". don't be suprised if i do something similar!
Old Oct 28, 2007 | 01:24 PM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
previous post removed. following DTN suggestion.
Old Oct 28, 2007 | 02:25 PM
Just wanted to restate that you should follow the manufacturer's directions on the can for preparing surface. When you put paint on a surface it pairs up with the surface, but only if you prepare it properly.
Old Apr 17, 2008 | 04:50 PM
01silvtiby's Avatar
Vehicle: 01 / Hyundai / Tiburon
quick question to sum everything, if i take the tire on the rim and gloss black it, how will it turn out and look?? cause im kinda confused
yea i think im going to try this cause one of my rims theres a yellowy paint showing through near the hyundai symbol
