DIY - Resetting your ECU
Old Nov 22, 2007 | 12:25 AM
  #41
I do 2 things to reset my ECU, every time.
1. Open the fuse box in the engine bay and remove the ECU relay.
2. Pull up the power connector.
That's it.
Old Nov 22, 2007 | 03:24 PM
  #42
my dummy lights come on and the engine will crank with both the ecu fuse pulled and the power connector up. Is there supposed to be something else? with the exception of the acessories, and the car not cranking up, the car seems like it's still got power. It cranks, but won't turn over.
Old Jan 8, 2008 | 04:58 PM
  #43
<div class='quotetop'>QUOTE (REDZMAN @ Nov 22 2007, 02:25 AM) <{POST_SNAPBACK}></div><div class='quotemain'>I do 2 things to reset my ECU, every time.
That's it.</div>
I tried that and it worked like a charm! That's the best method yet. I don't even have to discharge my capacitor anymore! Thanks Z!
Old Dec 10, 2008 | 11:14 PM
  #44
importtibby420's Avatar
sooo thats it just pull my ecu fuse relay out then pull up on the power connector and then right after that put the ecu fuse back in and press down the connector thats it no warming up the car or turning your key into the on position please some one let me know if im right
Old Dec 10, 2008 | 11:19 PM
  #45
Please use punctuation in your posts so we can tell what the hell you're saying.
Yes, as mentioned dozens of times by multiple members in the Shoutbox, just do it. There are several ways to reset your ECU: Pull the ECU relay, disconnect the battery, etc. etc.
Old Dec 11, 2008 | 01:10 AM
  #46
Evo's Avatar
Evo
Vehicle: 1997 Hyundai Coupe FX
if u disconnect the battery, remember to turn off the alarm 1st
Old Dec 11, 2008 | 06:46 AM
  #47
Please read and follow the forum rules.
Why would you need to let your car warm up before doing this? You CAN turn your key to the on position if you want, I don't think it'll make a difference my way.
