Diy: Replace Cam Position Sensor
Introduction:
If you have one of the following codes this DIY may be for you
P0342 Camshaft Position Sensor Circuit Low
P0343 Camshaft Position Sensor Circuit High
I replaced my CKP sensor as a part of troubleshooting a rough ilde and took pictures for this DIY.
Scope:
this diy will cover changing the CPS sensor
you will need:
small flathead screwdriver
10mm socket and wrench
Corona with a lime
Removal:
1. disconnect the plug connection from CPS sensor jack
a. remove connector from holder
b. remove connector clip from connector
c. disconnect electrical connection
2. Remove CPS sensor from engine
a. using a 10mm socket, remove bolt securing the CPS sensor to the head
b. apply a gentle wiggling motion to remove sensor from head
c. ensure that you remove the o-ring
prepare sensor:
1. if o-ring is in good shape, you may reuse it. It's best to replace the o-ring
Installation:
Installation is the reverse of removal
Scope:
you will need:
Corona with a lime
Removal:
prepare sensor:
Installation:
<div class='quotetop'>QUOTE ('diy rules")</div><div class='quotemain'>To post a DIY, please have all information available...
1. Where to get the product and price.
2. Tools needed and sizes of tools.
3. Sizes of wires, # of connectors, ect...
5. Help needed or what needs to be done professionally for safety sake.
6. Most important, PICTURES!!!
7. Do not post just links to a DIY. Please post the actual DIY here, atleast we will have the directions if the page ever goes down.</div>
Just following the rules.
