| Perilous_Tib_97 |
Feb 1, 2009 10:38 PM |
By searching through the forums and reading on other peoples finding on doing the fog light mod for the 97 Tibbys, i was reading what KCR wrote and i finally found the way to run the fogs with the parking lights:
Tools needed of course is the phillips screw driver, wires cutters, electrical tape.
Start off by taking the dash apart and getting to the fog switch then once you find the plug look for a wire with these colors Blue/Red strip, cut that wire and cap off the wire hanging from the connector, then from the harness get the Blue/red striped wire and cut a slip from the Green/Blk wire and connect them together, and once you turn the light on the fogs will turn on hope this will help the 97 Tibs and if anyone needs pics let me know and ill take them for you
