DIY - LED Window Switch Mod
Active Electronics:
EDMONTON
6029-103rd ST
Edmonton, Alberta, Canada
T6H 2H3 Tel: (780) 438-0644
Fax: (780) 438-0780
Email: edmonton@active-tech.ca
EDMONTON
6029-103rd ST
Fax: (780) 438-0780
alright i did this mod to my car worked fine, then i just did it to a buddies 99 tib, and everything worked fine until i put everything together now the dash/center gauges, and the window switches dont light up.... im thinking fuse, anybody know which one it is?
EDIT: yea was the fuse for the tailight, and a piece of electrical tape has slid off the power supply then grouded out on the metal inside the door so everything works good now. thx guys.
kayjai, working on a rd1 blower assembly, i figured out why you didnt really understand what my problem was. its because the rd1's dont have the problem,lol.
the rd2 blower assembly does have it though. you get the whole assembly out. when you go to remove the a/c and recirc buttons, you un clip them, slide them, but they get stuck. they get stuck because the little button cover(the part you touch when you push the button, and the part that has the windows for the light) is actually bigger than the opening for the rest of the button. so when you pull it, that plastic peice prevents you from being able to remove the button. and it is hard as f*ck trying to remove the cover peice the way its put on there. i usually end up breaking part of it to get it off.
that makes two DIY related things that i like more about the rd1s now. this, and their gauge clusters are less crowded, and more simply built.
