Diy: How To Hook The Automatic Aftermarket Knob Overdrive Button
Old Sep 3, 2003 | 09:14 AM
Djnevamind's Avatar
Default oil pressure sending unit
If you get a aftermarket shift knob with a overdrive button this is for you.
most overdrive buttons work off of two wires the 2001 tiburon has three
as follows here are the colors of the wires
red/white black/white yellow/white
the red and black need are the overdrive on
the red and yellow are overdrive off and turns on the od light on dash
now you have to use a relay 30 bosh and you have to fuse all power connections just in case you get the wrong wires 5 to 10 amp fuses
this is how you wire it up from the overdrive wires you should have 2 ground one to the the chassy
now take the other end of the overdrive wire and connect it to the 85 connection of the relay.
now take the 86 and connect it to the ciggrette light positive use a multimeter set to dc and the black meter side has a good ground
now probe with the red side of the meter and turn on ignition it should give you 12 voilts 0nly when you turn the key and nothing when you turn the key off this is the ignition wire that you will need fuse this with a 5 to 10 amp fuse please before you connect to it.
Now take the 30 side off the relay and connect it to the red/white wire
Now take the black/white and connect it to the 87a
Now take the yellow wire and hook it up to 87
the 30 on the relay is the main source the 87 and the 87a are the switching points
87a will always be connected when the relay is off
and 87 will only be on when you turn on the relay
in other words push the overdrive button to connect the od button and the ignition button the connection 85 and 86
now I have mine with the overdrive on at all times closed loop and when i turn on the relay it turns the overdrive off
so if you wanna do the reverse meaning have the over drive off without the button and it on when you use the button just switch the 87 and the 87a
in other words if you want to have the od off at all times just hook the yellow wire to the 87a
and then the 87 to the black wire
and keep the red at 30 on the relay
not reposable for installer error these are the colors that were in my 2001 tiburon use at you own means lol.gif
