Diy - Bbtb Install & Throttle Body Bypass Mod (free!)
Old May 13, 2006 | 01:00 PM
  #21
Macel's Avatar
Stupid question from a newbie here.. Im trying just to do just the bypass mod on the stock TB for now... It seems to me like I need to plug up the coolant intake nipples on the body itself, otherwise it would sort of defeat the purpose of having an air filter eh?
Old May 13, 2006 | 01:08 PM
  #22
dxtreamsktrxc's Avatar
crazy to put this but i can tell u this i have a 2000 tiburon and i tried to do this and i do not have those hoses on my tb lol crazy ??? confused.gif
Old May 13, 2006 | 01:11 PM
  #23
zoned019's Avatar
Vehicle: 97 Tib
dude..
you have to.
lol.
unless you have a bbtb?
there are no hoses running to/from your throttle body? (thats the part between your intake manifold and the rubber elbow piece fing02.gif)
Old May 13, 2006 | 01:21 PM
  #24
<div class='quotetop'>QUOTE (Macel @ May 13 2006, 01:00 PM) <{POST_SNAPBACK}></div><div class='quotemain'>It seems to me like I need to plug up the coolant intake nipples on the body itself, otherwise it would sort of defeat the purpose of having an air filter eh?</div>
No. coolant flows through there, not air. When you take the lines off, it'll dry out and that's it. No air goes in through there, otherwise you'd be sucking COOLANT in your intake.
<div class='quotetop'>QUOTE (dxtreamsktrxc @ May 13 2006, 01:08 PM) <{POST_SNAPBACK}></div><div class='quotemain'>crazy to put this but i can tell u this i have a 2000 tiburon and i tried to do this and i do not have those hoses on my tb lol crazy ??? confused.gif</div>
Either you don't know what you are doing or you bought a car with a aftermarket throttle body on it and the bypass is allready done. OR, someone ahead of you did this allready.
Old May 13, 2006 | 01:28 PM
  #25
Macel's Avatar
<div class='quotetop'>QUOTE (REDZMAN @ May 13 2006, 03:21 PM) <{POST_SNAPBACK}></div><div class='quotemain'>No. coolant flows through there, not air. When you take the lines off, it'll dry out and that's it. No air goes in through there, otherwise you'd be sucking COOLANT in your intake.</div>
Ah, makes sense (I wasn't sure if coolant was something that was okay to go thru the intake, I'm so noob) smile.gif
I attached the hose that was still connected to the TB back to the other nozzle in any case.. There's no problem with this, is there?
Old May 13, 2006 | 02:15 PM
  #26
Just as long as you did what it says in the DIY and looks like the picture, you are good. You just remove the 2 hoses from the TB, remove one from the Engine tube, and loop the other. Position the clamps, and you are done.
Old May 13, 2006 | 02:20 PM
  #27
lol i kno it seems nuts and yes i know what a tb and everything is lol ill post a picture on here of what im talkin about i followed the step by step instructions for that procedure and i can assure u that i do not have those hoses and i know i didnt put a bbtb on there lol ill post the pictures then u can tell me what u think
Old May 13, 2006 | 02:27 PM
  #28
zoned019's Avatar
Vehicle: 97 Tib
are there nipples on your TB for hoses?
it's possible that whoever owned it before you did this mod..
Old May 13, 2006 | 03:47 PM
  #29
im not sure ill take pictures but im almost pos that i do have the nipples on it but there are no hoses that hooked up to it and that u shaped hose design after this mod is done is also not there !!! >?????
Old May 13, 2006 | 06:36 PM
  #30
If there is no hose looped at the bottom, you are going to have some serious cooling issues, if you don't allready.
